Hole in stock intercooler
Old May 18, 2003 | 10:19 PM
my02_impreza's Avatar
There's a hole in my intercooler on one side of the 2 hoses. right underneath where the bolt connects there's a hole and I'm getting no boost... I put some JB weld on it to patch the hole up but it's still leaking and it sounds like my car wants to die but it's forcing itself to run.. Any ideas?
Thanks,
Anthony
Also, underneath where the 2 pieces of the manifold connect together, one of the bolts is stripped and the nut is stuck on there.. so it's loose right there and there's no way to tighten it or loosen it to get it off. I've tried virtually everything except cutting it. The only problem is there is not enough of the bolt to cut it successfully..
STi_Mark
May 12, 2007 09:25 AM
vietpunk916
Nov 10, 2006 11:17 PM
Z Man
Jan 27, 2003 07:12 PM
I3eXa
Jan 13, 2003 01:38 PM
Stickyfinguz
Jan 12, 2003 02:04 PM
