HKS downpipe
I have it on my car right now and it does the job like scoobysnacks said it doesn't have a full bell mouth designs so that about it. I've also heard that the HKS one uses the same design piping as the pde one with the exception that its one full pipe and not 2 pipes joined together (who knows if this is true...)
As far as performance goes it's OK.. you will have a 50-50 chance of getting a CEL so if you plan on purchasing this inexpensive (thats why i bought it... it's cheap!) you might start looking in to purchasing a MIL Eliminator.
Also you might want to look at what type of cat back system your planing to get (if you decide on that).
I own both the HKS downpipe and the Blitz Nur Spec catback exhaust and the 2 pipes don't meet up 100% so be ready for something like that to happen!
other than that you cannot go wrong with the price of the product! so if your looking for an inexpensive downpipe this might be the way to go.
Hope this helps a bit! Hope I don't start any arguements. I know if i posted this reply on the OTHER site it might spark an arguement. hehehe
Jon
Jon
Rallitek has a two piece stainless turbo back with cat and a flex joint 595 for downpipe and cat and 495 for catback. It is all polished from head to toe including the muffler you can see pics at
http://www.rallitek.com/pparts.asp?VEHID=1
They are the last two items on the page at the bottom.
The HKS is nice it's hard to go too wrong with a turboback or DP
WRX downpipe
Thanks for the input,
An alternative to the HKS that I am considering is XS Engineering's full system with an Apexi catback. I got a bit confused with the "midpipe" and "frontpipe" terms, but I guess that the two parts complement each other in forming what we call "downpipe".
The February 2002 Import Tuner added this combo on the WRX project car to their stage 1 mods (intake, exhaust and fuel tuning) and experienced a 29hp peak gain. Not too bad, with stock turbo-intercooler.
I don't intend to go wild with my car, but I surely want to reach 350hp on the wheels, without digging the engine internally. If I go with the HKS downpipe, I'll go with the HKS Hi-power catback too. I also want to eliminate two of the three cats', and MRT provides a CEL eliminator for that purpose.
Anyway, is 350hp doable with the HKS downpipe, assuming that I will change my turbocharger and intercooler?
Thanks,
Jgrams
Thanks,
Jgrams
Car Info: G35 Coupe (FOR SALE)
350 at the wheels is pretty wild in my book. I don't think that's possible without a turbo upgrade, in which case, you will have to look at the pricier bellmouth downpipes like (TurboXS, Godspeed, Scoobysport) or a twin dump design like the Perrin.
You can also look into the staged packages from Vishnu, TurboXS, and Godspeed. That will also enable you to see how much horsepower can be extracted from the mods.
www.Vishnu-Performance.com
www.turboxs.com
www.turboxs.com
Bellmouth design or non-bellmouth design. Can someone give me a straight story on which one is better for the car? I'm lookin to get a full exhaust system, an intake, ECU and some other little stuff. Which one do i want? Right now i'm lookin at the TXS stealth-back...
If you plan on staying with the stock turbo the HKS DP will work just fine. But if you plan on going to a big turbolike the PE1820 then get a bellmouth design DP.
Car Info: 02 GGA
I got the HKS and am very happy with it. I did get a cel light but fixed that with the help of Sub-Sonic. Its cheap and it does the job. But the Helix dp from www.gruppe-s.com looks promising.
Re: ?
350hp to the wheels is definetely a bit wild in my book. with some aggressive tuning and upgrades to the rest of the car that will support it, you MIGHT be able to achieve this with a vf-30, 34, or 35, though i'd say the turbo is definetely the limiting factor here. a larger turbo like the vf-22, greddy t518z, pe1818/20, etc., may be a better choice.
keep in mind that imprezer is making 300hp atw with a t67, greddy r-spl fmic, 18psi of boost, pump gas, tec-3, stock internals, and loads of other mods that will leave you drooling, though i'm pretty sure we'll be seeing higher numbers from him once he sorts out his new drivetrain and hopefully his uhh...displacement issues
. also keep in mind that the 300hp figure is off of shiv's dynamics dyno on which a stock wrx averages at ~165hp.oh and if you end up getting a japanese exhaust, that is, a catback designed for the jdm wrx, be sure to get a jdm downpipe as well. the lengths of usdm and jdm catbacks/downpipes are different.
flatline
Apr 18, 2008 09:36 AM
ASpec818
Apr 7, 2004 02:04 PM
(==ImPrEzAWR==)
May 17, 2003 11:22 PM
