HELP with universal APEXi N1 muffler .
Old Mar 4, 2004 | 04:47 PM
Ibobby dI's Avatar
hey wassup guys . i got a pretty good deal on a APEXi N1 muffler . i was thinking of going to a muffler shop and getting them to weld it to a 3" pipe from the catback . is this okay ? is there anything i should ask him . i think i read something about what they should use when theyre bending the piping . any inputs i would appreciate it very much . and also , if i do do this 3" catback to APEXi N1 muffler ..... will i stil be able to BOLT on an aftermarket up-pipe and downpipe ? theyre 3" too right ? ( godspeed , helix ...... ) thanks alot fellas !
Old Mar 6, 2004 | 12:58 AM
caterpill's Avatar
Car Info: Rust bucketo
I believe that you should be fine as long as the muffler shop does not modify the stock flange location or type. Since it is from the cat- back, it wouldn't prevent you from changing your upipe or downpipe.
Old Mar 7, 2004 | 09:45 AM
Need4Boost's Avatar
Car Info: GDA w/ RA-C & TO4E
Make sure they mandrel bend the pipes. Tell them to use at little bends as possible.
TURBO
Apr 19, 2006 12:14 PM
HartgeM3Power
Apr 2, 2006 01:56 PM
dayton100
Oct 9, 2003 09:10 PM
susu
Sep 4, 2003 02:33 AM
jhong567
Jun 27, 2003 02:19 AM
