HELP! Removing the O2 Sensor on the Catty
Old Mar 21, 2006 | 07:36 PM
1FSTREX's Avatar
Car Info: 2018 STI Limited
Hey there,
I am taking my stock DP off and putting on a aftermarket one. I got everything off but ran into the problem of the O2 sensor in the Catty. I looked at it and tried to pull and that didnt work, tried to losen the nut on it and that didnt work.
HOW DO YOU GET THE O2 SENSOR OFF THE CATTY?!?!
Any help is appreciated.
THANKS!
Will
Old Mar 22, 2006 | 03:23 PM
wvinfernovw's Avatar
Car Info: 2004 wrx
o2 senor socket, you tried that?
Old Mar 22, 2006 | 03:50 PM
RU-X's Avatar
Car Info: 05 wrx
no real need for a o2 wrench, anywrench that fits will do the job
Old Mar 22, 2006 | 07:07 PM
bluewrx82's Avatar
Wd40 Can Help Too
Old Mar 22, 2006 | 07:12 PM
bluewrx82's Avatar
try to disconnect the o2 sensor, and undo it off the car. sometimes the are a pita to take off because the everytime you loosen up the sensor, the harness twists and makes it a pain in the butt to get out.
Old Mar 23, 2006 | 11:54 AM
symby's Avatar
Car Info: 2002 Impreza WRX
We needed a torch to get mine out. Little bit of heat and it finally loosend up. It was in there REAL GOOD. We used an open ended wrench (20 or 22 mm something like that). Of course the downpipe was off the car when we did this.
Old Mar 23, 2006 | 01:25 PM
subie OCD's Avatar
Car Info: 04 STi
this is the easiest way
polishwrex
Jan 7, 2009 12:25 PM
Peaty
May 30, 2008 09:58 AM
NorCalDC5
Jul 22, 2007 11:44 AM
Wildblitz1337
Feb 18, 2006 06:35 PM
