Help, high underhood temps.
Old Aug 16, 2003 | 09:31 PM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
Exclamation Help, high underhood temps.
I have been doing big work to my car and decided I should log some underhood temps.
Before I had any work done, I had a max temp of less than 170 degrees, that occured after shutting the car down and letting it sit in the hot (100+ degrees) sunshine.
With the car running, my underhood temps rarely exceeded 130 and generally, as long as I did 25+ mph, they usually ran below 100 degrees or about 10 degrees hotter than ambient air.
Now my car is a monster, as long as the underhood temps are below 100. Car still drives well with underhood temps to 140. When underhood temps get above 140, my car doesn't drive as well. In the winter I won't expect this to be a problem, but in the hot summer days it is.
Q: Anyone know of any ways to cool out underhood temps?
Note: EGT's are at or below 1500, tapped off of cylinder #3
Old Aug 17, 2003 | 10:23 AM
ride5000's Avatar
have you wrapped or insulated any exhaust components?
where is your intake air coming from?
i assume you also have a TMIC?
ken
Old Aug 17, 2003 | 11:59 AM
ken
Yes, I have a TMIC - Stock for now.
No exhaust parts are wrapped.
Air intake is stock.
pimpsti
Apr 2, 2005 10:52 AM
AntiochCali
Sep 29, 2004 01:54 PM
madrex
13
Oct 19, 2003 11:27 PM
billjr212
Apr 20, 2003 04:34 PM
