help...boost problem
Old Feb 10, 2004 | 10:36 PM
MJU1983's Avatar
Car Info: 06 Armada, 03 WRX, 05 STi(sold), 05 Vette (sold)
Pull the line off the wastegate and go run it... See what it does, but watch closely as you dont want to blow anything up
-Mike
www.axispowerracing.net
Old Feb 10, 2004 | 11:43 PM
MJU1983's Avatar
Originally posted by GDBlitz
do you mean the actuator, because Tommy from MPJ tried that and it hit 1 bar and he let off because he didn't want to over boost it. but he did managed to get higher boost.
Well you have two lines. One on the wastegate. and one on the compressor of the turbo.
If you pull the wasegate line, you should make almost instant boost. But yes its not controlled.
If it makes the boost, then you know the turbo isnt the problem.
Try a different method of controlling the boost.
-Mike
Old Feb 11, 2004 | 12:01 AM
MJU1983's Avatar
i tired both the greddy and the stock boost solenoids, what else should i try?
thanks
I had a similar issue with my car not wanting to build boost the proper way. I made the MBCs that were on my car.
Just keep trying until something works. It has to be in the controllers if the turbo is fine.
-Mike
Old Feb 11, 2004 | 10:29 PM
What mods do you have? If the car isn't working stock, take it in under warranty. Normally your warranty would be useless after using a boost controller, but since it may be the stock solenoid itself that is bad, they should be willing to take a look, as long as you don't have too many other power mods.
Old Feb 12, 2004 | 01:17 AM
Pull the boost lines off one at a time and check, but start with the one that has the restrictor in it. Sometimes it can get turned sideways, and block the signal completely.
yzercyber
Aug 12, 2005 03:42 PM
ton43
Jun 2, 2005 12:31 PM
TWRXT
Feb 12, 2005 01:50 PM
GDBlitz
Mar 13, 2004 02:36 PM
STI Blast
Oct 10, 2003 10:22 PM
