help!!!!! about hose
Old Nov 6, 2007 | 09:04 PM
fm725fm's Avatar
Car Info: Works xD sTi
when i trying to clean my engine bay, saw this hose cracked....anyone know where can i get this? and hard to replace?
Old Nov 6, 2007 | 09:05 PM
VRT MBasile's Avatar
thats the y-pipe, easy as hell to replace, just get an after market one
Old Nov 6, 2007 | 09:07 PM
fm725fm's Avatar
is there any size different? angle? i need to take off the tmic to replace that right? any link to that product?
Old Nov 6, 2007 | 09:08 PM
they can be found here
http://www.subydude.com/osc/index.ph...b76171eabe53b0
to remove the intercooler remove all the little black hoses attached to it and loosen the clasp on that cracked hose as well as the same clasp on the top of the short hose that connects the intercooler to the intake manifold. Then undo the two bolts (one bolt on either side)and wiggle the intercooler up and to the right (away from the turbo and the intake manifold). Once you flip of the intercooler, the y-pipe should be pretty easy to take off. Install the intercooler in the reverse order, make sure you reattach all hoses
Old Nov 6, 2007 | 09:22 PM
fm725fm's Avatar
http://www.subydude.com/osc/product_...b76171eabe53b0
so i need to get this right?
Old Nov 6, 2007 | 09:24 PM
that one, along with any of the other y-pipes on the page will work
Old Dec 4, 2007 | 10:45 PM
CharT's Avatar
Car Info: 2003 WRX Wagon
I thought that the STI intercooler has a different Y-pipe than the WRX?
Old Dec 4, 2007 | 11:04 PM
thats actually very true, hopefully the original poster found that out before hand and got the correct part
Old Dec 5, 2007 | 03:14 PM
I dont think that will leak
put it under boost and see what happens
View Askew
Nov 3, 2005 09:11 AM
A.V.E.
Jul 7, 2005 04:58 PM
Indirecked
Jun 17, 2005 12:46 PM
DJTEN4
Jun 19, 2004 10:52 PM
maku
Jan 2, 2004 06:00 PM
