Helix uppipe/downpipe any good? (was: I Need Help)
Old Aug 7, 2004 | 11:51 AM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
Thumbs up
Originally Posted by union rex
so is a helix up pipe any good i was about to get the helix up and down pipe but i wanted to find out more about them first im going for the most hp increase so would the helix be best ? or is there a better brand ? im trying to keep with a reasonable price so plzZz let me know
Traditionally the up pipe won't give you that much HP, if any for that matter, however it will give you increased / sooner spool. The helix flex is a very good option for it will decrease the chances of leakage in comparison with a non flex cheaper one. And leakage will rob you of spool and valuable hp. If you havent done so may I recommend a downpipe, devorced wastegate or bellmouth design to be installed at the same time. The DP has to be disconnected to do the UP install so you mide as well do it while your there; and you will notice a HP increase from this.
$02
-K
Old Aug 7, 2004 | 12:58 PM
namitherussian's Avatar
Car Info: Black WRX
check out the review section about up/downpipe, great product, go for it
Old Aug 7, 2004 | 10:22 PM
Kwilson21's Avatar
well i am planning on getting both the helix up and down pipes at the same time so i will be getting the down pipe as well
ok. Then you want to concentrate on the DP. Pay attention to the bellmouth of devorced wastegate designs, not sure if the helix offers this in there DP, they will provide you with the most HP due to least amount of tubulence for wastegate exhaust.... they cost a bit more but if you ultimatly plan on replacing the turbo then this is definitly a good way to go for maximizing flow.
The only thing negative that ive heard regarding the helix products is some fitmeant issues othther than that they are rocken.
-K
Old Aug 7, 2004 | 11:05 PM
Kwilson21's Avatar
If you do it yourself dont forget to get new gaskets for both the manifold side and turbo side of the UP.... and the turbo side of the DP.... to replace the crushed once you'll be removing. You'll cut your leakage potential in half if you do this... even with the flex section worken for ya.
O and if your not machanically inclined...... its not as easy as it looks....the UP that is.. the DP is easy.
good luck.
-K
Old Aug 8, 2004 | 11:32 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
you shouldnt have any fitment problems with helix products, every helix product i have fits perfectly.
Old Aug 8, 2004 | 12:05 PM
blue blurr's Avatar
helix up/dp are awsome i have them along with there cat back and love it. you will deffinitly feel a difference with the up / dp combow, you wont be dissapointed
Old Aug 10, 2004 | 08:55 AM
chicote's Avatar
Car Info: 02 wrx wagon
One more for the Helix products!!! Its a great price and a great product. Everyone I know who has looked at these pieces loves them! I have it installed on my 02 wagon and love it! Enjoy and do your self a favor and install both at the same time. I got mine from Gruppe-s for a good price.
Cheers and happy driving!
Old Aug 18, 2004 | 02:17 PM
boardertj's Avatar
who has run a helix downpipe with the stock catback? how was the fitment? ive heard there have been problems.
Old Aug 18, 2004 | 02:38 PM
RoadSpike's Avatar
Helix is a 3" downpipe while the stock is 2.5" so you'd need an adapter or some welding to make it work.
A PDE downpipe is 2.5" at the end though and should bolt up.
ASpec818
Jun 8, 2006 10:21 PM
jc0019
16
Oct 18, 2005 12:06 AM
jc0019
Sep 29, 2005 11:58 PM
nathanellis
Jan 14, 2005 04:08 PM
