Headwork
Old Nov 15, 2004 | 10:57 PM
topnotchwrx's Avatar
From: Just when I find the key to success, someone goes and changes the locks.
Car Info: "Why Warthog sir?"
Headwork
I just got my car back from the shop that was doing alot of work to my heads. All I can say is that the car pulls alot smoother than before. The work performed was a port and polish, five-angle valve job, 1mm oversized valves, and port matched exhaust manifold. Here are the pics of the heads.
http://img.photobucket.com/albums/v2...ictures034.jpg
http://img.photobucket.com/albums/v2...ictures035.jpg
http://img.photobucket.com/albums/v2...ictures036.jpg
http://img.photobucket.com/albums/v2...ictures037.jpg
http://img.photobucket.com/albums/v2...ictures038.jpg
http://img.photobucket.com/albums/v2...ictures039.jpg
http://img.photobucket.com/albums/v2...ictures040.jpg
http://img.photobucket.com/albums/v2...ictures041.jpg
http://img.photobucket.com/albums/v2...ictures042.jpg
http://img.photobucket.com/albums/v2...ictures043.jpg
http://img.photobucket.com/albums/v2...ictures044.jpg
http://img.photobucket.com/albums/v2...ictures045.jpg
http://img.photobucket.com/albums/v2...ictures046.jpg
Old Nov 16, 2004 | 07:21 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
I have always wondered what that would do for my EJ20. Any other info you can give, how much did it cost ? Dyno results ?
Rush
Old Nov 16, 2004 | 08:36 PM
Cost wise with the work and parts it all came together at about $2000. I havent gone to the dyno yet but i will try to as soon as possible. Only other thing I can say is if you ever have the motor ripped apart and have the opportunity to have someone do the work, go for it.
Old Nov 17, 2004 | 02:58 PM
Donkey's Avatar
Car Info: 02' WRX
Are you running the tumbler deletes with your new head work?
Old Nov 17, 2004 | 06:52 PM
if im not mistaken they are used to get the right air/fuel mixture on cold starts. and the climate in sac is currently cold and getting colder so i dont think it would help. if i was in a mild climate that would have been one of the first on the to do list.
Old Nov 17, 2004 | 06:54 PM
WRX Rush's Avatar
What is the advantage to tumbler deletes ?
Rush
Old Nov 17, 2004 | 07:39 PM
less restricted air flow = more powa!
Old Nov 17, 2004 | 09:05 PM
WRX Rush's Avatar
Like how much ? I am wondering because I am new to the whole head renewal thing. Do tumblers create some kind of turbulent backpressure into the cylinder head or something ?
Rush
Old Nov 17, 2004 | 09:33 PM
here is a link to APS's kit :
http://www.airpowersystems.com.au/wr...ems/tdi_01.htm
Old Nov 17, 2004 | 10:52 PM
WRX Rush's Avatar
Spanks! I wonder how bad the cold starts would be in the bay area without tumbler valves. . .
Rush
Old Nov 18, 2004 | 01:22 AM
from what ive been hearing, on startup the car runs very rough for the first 5-15 minutes. after warmup it should go back to normal.
25RS 2NV
Nov 25, 2002 09:48 AM
