Gt35r
Old Feb 6, 2007 | 07:58 PM
Teddy's Avatar
Car Info: Subaru JDM Type RA
Gt35r
Hey im lookin to put the GT35R ball baring turbo on my subby.....lookin for some pros and cons of this tubo application, thanx
p.s with around 28 psi, forged motor, gems stand alone ecu, walbro fuel pump x2...and some other good stuff
Old Feb 7, 2007 | 05:00 AM
testes1010's Avatar
If you're stuck on the GT-R series turbos go the Ultimate Racing(UR) kit....best one on the market, IMHO.
Otherwise I'd recommend the UR T3/T04S kit, quicker spool & more topend than the GT35R & its less expensive.
Ball bearing turbos are completely overrated & overpriced.
Old Feb 7, 2007 | 06:56 AM
ipozestu's Avatar
Car Info: Broken Subarus
I'm going to go out on a limb here, but is this a wise choice for an EJ20?
Old Feb 7, 2007 | 06:59 AM
testes1010's Avatar
he said forged motor, so I'm assuming its built properly. A GT35R will be laggy on a 2.0L but high CR forged motor can take it.
Old Feb 7, 2007 | 12:37 PM
Jake's Avatar
he will probably have to think about a stronger transmission as well...
Old Feb 7, 2007 | 12:56 PM
ipozestu's Avatar
That was where I was going, it's going to be laggy as hell.
Old Feb 7, 2007 | 03:34 PM
Superglue WRX's Avatar
That's just too much lag for a 2.0 liter. And 28psi, do you expect to run that kind of boost on pump gas? And when's the soonest you can reach that kind of boost, 4500-5000 RPMs? I could never live with that kind of lag.
I don't know what this guy's goals are, but I'm just going to say 18G, and keep it reasonable. It's not a Supra.
Old Feb 7, 2007 | 03:47 PM
ipozestu's Avatar
For that size turbo you'll seriously want to consider a 2.5L. Even with forged internals the block design of the 2.0L is really inferior to the 2.5L's semi closed deck. At least consider a 2.2L they can be built and stroked. A JDM 2.0 can handle some power, but your still be dealing with the lag. Reconsider.
Old Feb 10, 2007 | 11:18 PM
WRX409's Avatar
Car Info: 04 WRX
On the EJ20 powerplant the GT35R will not spool quick and
efficiently like the Mitsubishi TD04H will.For street or highway
driving you mite not like it because it will be laggy.Depite the
set-backs of the GT35R it will make alot more power but,you
will feel the power big time when it does finaly spool.
If I were you I would consider a 16g or 18g instead.
Old Feb 11, 2007 | 09:20 PM
Teddy's Avatar
well i aint worryin about the lag the ecu has a anti-lag system which prevents the turbo from despoolin, so i always have at least 8-12 psi b4 i go full throttle. i kno that with the 35r i'll have a lag cuz of the size of the turbo but im lookin for 600 hp, the tranny is a dogbox so i aint worryin about that
Old Feb 12, 2007 | 01:43 PM
Someone correct me if I'm wrong, but wouldn't anti lag pretty much disintegrate a GT35R within a few thousand miles? There aren't that many turbos out there that can run with anti-lag for an extended period of time. And from what I've seen, they cost a few thousand bucks.
And 600HP??? I assume you plan on using the EJ207 block because you'll never come close to that with an EJ205 (USDM) block. Do you mind me asking what you need 600hp and antilag for? At first I assumed you wanted a drag car, then you mentioned the antilag. Time attack maybe?
And I take it you have no intention of driving this on the street (vis-à-vis the dog box)?
Old Feb 21, 2007 | 06:52 AM
Teddy's Avatar
no.....no street application jus all out drag car, that was my next question actually, can the ej20 support 600 hp ??.......he antilag is about 8psi it'll be a while b4 it harms tha turbo
Old Feb 21, 2007 | 01:54 PM
Why anti-lag on a drag car? I can't think of any part of drag racing where anti-lag would be helpful. When you launch, you already have the rpms up and the turbo spooled. When you travel down the track, you should not be dropping out of your boost range, especially if your using a dog box gearset.
WrbImprezaSti
Jan 19, 2007 05:28 PM
god
Jul 4, 2005 06:16 PM
Ender2664
Mar 7, 2004 09:48 AM
