Greddy EVO 2 on 02 wagon
Old Jun 29, 2011 | 04:12 AM
Urban_Grey_2.5's Avatar
Car Info: Norco 29er Mtn Bike
Just mounted the exhaust up last night and on the test drive I noticed a thumping under the car when I left off the gas while in gear and also when I take a corner fast, do you guys think longer exhaust hangers(kartboy) would fix this problem?
Old Jun 29, 2011 | 04:33 AM
xhengmanx's Avatar
more then likely its hitting the rear diff housing as alot of exhaust has this issue or is very close. extended hangers is a possible fix depending on there it touches. Try jacking up the car and check to see where its rubbing to determine if an extended hanger is needed.
Old Jun 29, 2011 | 06:21 PM
Thanks for the advice, going to work on it Friday after work
Old Jul 1, 2011 | 01:51 PM
Well it's not hitting anymore(still ordered kartboy hangers) I think what happened is that I used a little dish soap on the exhaust so it would slide easily into the hangers and the soap was to oily causing the exhaust to slide around in the hanger. Live and learn LOL
anoxi
Feb 24, 2007 02:31 PM
East Bay STI
Feb 25, 2006 01:21 AM
nathanellis
Mar 6, 2004 10:50 AM
