Got a problem with boost..
Old Jan 25, 2012 | 10:09 AM
esousa22's Avatar
So yesterday I get a call from a buddy of mine, also on the forum, and he has a problem boosting. When he drove to work yesterday, a tube that connects to his forge BOV popped off and now his accessport is saying hes steadily hitting 23.8-24.2 psi (20-21psi normally) but the car isn't pulling like it should. We tried turning down the boost with the HBC and that seemed to help but we turned it down all the way and it still wasn't like it should have been. We took off the topmount to have good visuals of the lines to look for leaks and nothing...
2004 sti with mods that I recall:
gt3071r ball bearing turbo
not sure on injectors
hallman manual boost controller
headers
spt short ram intake
invidia bellmouth catless dp
hks hi-power catback
perrin topmount
He put the headers and swapped his cold air for the short ram 2 weeks ago and hasnt tuned it with them yet, could that be the problem?(yes we know it needs to get done, just havent yet). The wastegate I think is closed.. the arm is perpendicular to the metal piece connected to it.
Any input will help, we are both learning these cars.
*Update Edit
-Found a crack in a line underneath the intercooler inlet hose into the turbo
-Found a gas leak under the intake manifold
-Brought the car to Garage 1 and so far everything has added up to $950 with them taking off the downpipe and turbo to get to the hose, put on his aftermarket uppipe, taking off the intake manifold to get to the gas leak...
Old Jan 25, 2012 | 06:55 PM
esousa22's Avatar
bump
Old Jan 26, 2012 | 10:28 AM
MarvZz's Avatar
Car Info: 03 wrx
Have you checked to see of all the houses are connected? I don't know much, but I would try to switch back to the mods before the problems happened and see what that does.
Old Jan 26, 2012 | 10:35 AM
esousa22's Avatar
thats a lot of work... I'd rather not go that route... haha thanks though
Old Feb 3, 2012 | 08:44 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Sounds like a leak or crack in one of the boost control lines or possibly an issue with the wastegate.
-- Ed
Old Feb 3, 2012 | 10:11 AM
esousa22's Avatar
-- Ed
There was a crack/rip in a line underneath the intercooler inlet hose that connects to the turbo. Whats the name of that line? its about an inch or 1.5 inches in diameter.
Doesn't seem to be the wastegate, I believe its fully closed and fully functional.
Old Feb 3, 2012 | 10:25 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
If you're talking about the small vacuum/boost line, its one of the boost control lines.
-- Ed
Old Feb 3, 2012 | 10:31 AM
esousa22's Avatar
-- Ed
Nope, talking about a thicker line, well its thicker than most boost lines because I'm familiar with installing boost gauges so I know which ones are those lines unless there is one that is probably the diameter of a half dollar.
Thanks for chiming in Ed!
Old Feb 3, 2012 | 10:33 AM
SkizzDawg's Avatar
Car Info: 2006 STI
your not talking about the house that goes from the turbo outlet to the IC inlet are you?
Old Feb 3, 2012 | 10:36 AM
esousa22's Avatar
nope, its just underneath that one, I believe the one you are talking about is actually called the intercooler inlet hose if I'm not mistaken but I'm still learning so
Old Feb 3, 2012 | 10:39 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
A picture would be very helpful
-- Ed
Old Feb 3, 2012 | 10:42 AM
SkizzDawg's Avatar
Car Info: 2006 STI
-- Ed
+ 1 This
Old Feb 3, 2012 | 10:53 AM
esousa22's Avatar
Put them up when I get them
Old Feb 3, 2012 | 01:22 PM
Gancherov's Avatar
Car Info: 02 WRX Wagon
Only line i can think of that is that big in that area is the BPV hose, right?
Goes from the bpv/bov valve on the front of the intercooler (think you said he had a FORGE brand bpv/bov?) NEXT to the throttle body down to the turbo inlet where it dumps the pressurized air in front of the compressor wheel. [to maintain spool during gear shifts and prevent compressor surge]
I bet it popped off because he has a silicone replacement for the OEM rubber hose. those silicone ones are slippery bastards. Not sure if that would cause the problems he is having though...in combination with gas leak that ruined other lines maybe?
Old Feb 3, 2012 | 01:38 PM
Gancherov's Avatar
This line? (I can't find a better pic of this hose in the FSM)
Top
