fuel smell
fuel smell
lately ive been smelling fuel, after i fill up, and under load..ive done the search that the "fuel pump assemble gasket" needs to be replaced after opening up the pump assembly...but my question is that would the gasket not sitting correctly throw a check light....and i do need the car to get to work, so by continuing to drive with the gasket not sitting correctly or worn out is it going to cause serious damage to my motor?
-vf34 setup from gruppe-s w/ accessport
-helix down, HKS up, invidia exhaust....
much info would be great
-brendon
-brendon
Car Info: 2002 WRX
I would imagine that the gasket not being fully seated would be very similar to not having the gas cap tightened down which can cause a CEL. I would either replace it, but at minimum I would re-seat the gasket until I could get it replaced. I don't think you'll have any engine damage, the tank isn't pressurized, only the fuel line.
well as for the cap...i make sure its on tight ( click it a few times)..
i changed out my fuel filter 8k ago...
double checked all fuel connections to the filter as wel my injectors...
removed back seat, while car was running to locate the smell...and it came from the area the fuel pump is...gotta get a CEL reader to be sure...thankz for all the input
its more than likely the fuel pump gasket, I misaligned mine when I swapped pumps out.
yea im goin straight pipe...but the smell hasnt occured until recently
i was on the vf34 turbo for about a year now...and this raw fuel smell has came up just recently, past few weeks...i understand that goin catless there will an odor of some type...but ive did my process of elimination, and came to realize the fuel pump
all your replies are much appreciated...thanks again
I have that smell ever since I got my 34 installed. It's pretty bad and ihave to throw on the air recirculation. I was thinking that i am running the of the shelf map from AP and that it could be running too rich. I will see what happens after my protune
VRWRX
80
Aug 28, 2011 01:26 PM
Munashi
May 6, 2004 04:42 AM
JohnB
Jun 30, 2003 12:14 PM
