First mods to my WRX
Old Feb 25, 2004 | 12:19 AM
GO24JUNIOR's Avatar
Car Info: Subaru WRX 2002
Hey guys it's Mike again. I'm bout to make my first mods to my WRX. I want to go Perrin Up pipe, Down pipe, and an APEX'i GT Spec catback is that a good choice for my first mods? Also is that a good setup or what? Let me know guys thanks:banana: :banana: :banana:
Old Feb 25, 2004 | 12:26 AM
TurnWRX's Avatar
can't go wrong with the perrin pipes I'd say that's a good setup u have for exhaust. It'll be loud though.
Old Feb 25, 2004 | 12:28 AM
eh pipes are pipes youll notice the difference
Old Feb 25, 2004 | 12:29 AM
GO24JUNIOR's Avatar
I was planing on going all cat less but would it be best for me to use the Perrin Down pipe with the high flow cat instead of cat less?
Old Feb 25, 2004 | 12:35 AM
TurnWRX's Avatar
Depends on what you want. If you want max power, I'd go catless. If you're concerned about the environment and want to be more eco friendly, go with the cat. But FL doesn't require emissions testing right?
Old Feb 25, 2004 | 12:38 AM
GO24JUNIOR's Avatar
No Florida doesn't require emissions testing so catless is the way then?
Old Feb 25, 2004 | 12:48 AM
TurnWRX's Avatar
like I said, depends what u want. You want max power go catless. You want to be a lil more eco friendly, go with the cat.
Old Feb 25, 2004 | 01:31 AM
Daredevil's Avatar
im in cali and catless, and i love it
Old Feb 25, 2004 | 05:50 AM
wrx10404's Avatar
Car Info: 04' wrx
That's why your the "DAREDEVIL".
Old Feb 25, 2004 | 09:14 PM
mike626's Avatar
Car Info: 2003 WRX
Just curious daredevil, when it comes time for smog check, how do you plan to pass it? I live in CA too and im considering going catless as well.
Old Feb 25, 2004 | 10:20 PM
TurnWRX's Avatar
swap back the stock dp and mp
Old Feb 25, 2004 | 10:24 PM
GO24JUNIOR's Avatar
I got a question bout the setup guys. Will the Perrin down pipe fit the APEX'i GT Spec cat back?
Old Feb 25, 2004 | 11:10 PM
Flash N Dash's Avatar
Car Info: WR Blue WRX
GO24JUNIOR - In theory it should fit, BUT not all cat backs will fit all downpipes. Sometimes you can get away with mix and matching exhaust pieces and not have any problems like exhaust leaks. But in my opinion if you want to keep it safe then just get all of one type exhaust and that way you are guaranteed to not have any fitment issues.
The Perrin full Turbo Back is a high quality system and you will get just as much HP when running catless as you will trying to mix and match the two pieces.
If you are interested in getting either set up then hit me up and I would be glad to take care of you!
Daredevil and mike626 on this thread can vouch for me on my rep on here!
Thanks,
Brian
Flash N Dash Performance
Old Feb 25, 2004 | 11:37 PM
GO24JUNIOR's Avatar
Brian,
Will they fit can you find out and how much will it cost for you to get me Perrin up pipe, down pipe and APEX'i GT spec catback?
Old Feb 26, 2004 | 11:09 AM
GO24JUNIOR - Checked into it for you and one of my suppliers is actually running that exact set up now on his WRX with no problems! So that is cool!
For the Perrin Uppipe and Downpipe and the Apexi GT Spec Cat Back would be $1215 shipped!
To place an order, send funds through PayPal to autransam@earthlink.net and I will take care of the rest!
Let me know if you have any questions or if this works for you then I look forward to hearing from you!
Thanks,
Brian
