engine stutter at half throttle
Old Apr 28, 2003 | 08:12 PM
hotrod's Avatar
check you utec
Sounds to me like your utec program needs a tweak. Give Nathan a call and run it by him. Or check with the guys on wrxhacker.com.
When you checked your grounds you did an ECU reset, over time it learned something that makes the programing error show up. If I had to guess your a bit too lean in that rpm range.
Larry
Spoolem
Apr 12, 2014 08:12 PM
burndtjamb
Dec 27, 2005 02:18 PM
black02
Nov 3, 2005 07:34 PM
vixhex
Jul 7, 2004 10:32 AM
