Engine Check light
Old Nov 4, 2006 | 06:01 PM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
Question Engine Check light
I have a problem with my car. I just put in my downpipe last week and while i was on the freeway my check engine light turned on. I found out that its because i removed the cat. But my question is this. Can i fix with problem with a cobb accessport instead of a cel fix?
Help appreciated!
Old Nov 4, 2006 | 07:40 PM
Superglue WRX's Avatar
Both solutions will take care of the check engine light.
Of coarse, the Cobb AP is a more expensive solution, and the new ones are all on back order right now. I would suggest you do the electrical fix for now and just by the AccessPort later when you have the money and it's more readily available.
You have an '03 so it will be fine running a down pipe with no EM for a while. The AP is going to make a significant increase in power and is esential for future upgrades.
Cheers!
Old Nov 4, 2006 | 08:01 PM
thekid925's Avatar
Car Info: 05 obp sti
Cheers!
I say get both
Old Nov 5, 2006 | 11:32 AM
WRX>Civic's Avatar
ahh! Thankz I think I'm going to get the COBB because I was planning to get it... i have just enough saved up for it! xD
Old Nov 6, 2006 | 01:01 PM
wrecker83's Avatar
Car Info: JDM STI V7 EWG powered 2003 Subaru MBP WRX
im getting the same thing. i installed an uppipe around 3months ago or so, and have had some issues.....thinking the install wasnt good. would the cel pop up if theres an exhaust leak? my car is bone stock except for the catless uppipe. let me know what you think. thanks
Old Nov 6, 2006 | 02:55 PM
Wingless Wonder's Avatar
Origami posted by wrecker83
im getting the same thing. i installed an uppipe around 3months ago or so...
Catless uppipe generates a different CEL code than the downpipe. It's always best to get the code read to determine which error code is causing the CEL.
If the catless uppipe is your only mod, chances are the catless uppipe CEL fix will take care of it. You can find a link to that thread in this 'stickied' post at the top of the forum.
Old Nov 6, 2006 | 09:02 PM
WRX>Civic's Avatar
Do i have to have gruppe-S to do the downpipe CEL fix for me?
Old Nov 7, 2006 | 08:50 AM
no you can scan the code and just let it be
or you can get a tune
or you can get a fix yourself and put it in
Old Nov 7, 2006 | 09:18 AM
skeeler's Avatar
Car Info: 05 WRX sedan
I had the same problem right after i got my UP and DP on, both catless. I then got my AP and took it to s-squared to get it tuned by Nate (i think) and he said the reflash turned off those codes. I have the CEL fix on my DP but I think it was the UP, at first I thought the CEL fix did not work. Is s-squared still around? I might get a VF-39 and I wanted that same dude to tune it.
Old Nov 7, 2006 | 11:34 AM
S-Squared is no more. For local tuning, contact EQ Tuning or Paul@dbtuned.
Old Nov 7, 2006 | 12:28 PM
strider327's Avatar
Car Info: 2005 WRX
For those of you having the CEL's because of the up-pipe and downpipe. Here's what I did:
Up-pip Fix:
I for one removed the EGT sensor completely and pluged the hole with a 12mmx1.25 Oil Drain bolt and slapped on a 2.2 KOHMS 1/2% Watt resistor from radio shack. That took care of the CEL completely.
Downpip FIx:
There are 2 ways to do this. You can either go the electrical fix (same thing as the resistor) Or you can do the mechanical fix which consists of two Anti Spark Plug Foulers. It looks like two fat screws. You'll have to drill one out completely and screw it onto the other and then screw the 02 sensor onto the end of the undrilled one. and your set. No CEL. To get a clue of what the bolts look like....
http://cgi.ebay.com/ebaymotors/WRX-0...ayphotohosting
Old Nov 8, 2006 | 08:50 PM
wrecker83's Avatar
sorry, im sure this doesnt belong here, but im new to the site and cant find certain things. i needed to know if there is a shop close to Fairfield, Vacaville area. also, what would it run for them to check out my 03 wrx for exhaust leaks, and maybe installing new gaskets for my uppipe ect. ? i have a bone stock wrx besides my catless uppipe, and i think the guy who installed it didnt "really" know what he was doing and im mechanically inclined. any help would be appreciated. thanks!
Old Nov 8, 2006 | 09:13 PM
Maybe Fine Line Imports in Santa Rosa or LIC in Novato. Either shop could handle the exhaust work you require. You could give them a call for price quotes.
Old Nov 8, 2006 | 09:32 PM
wrecker83's Avatar
thanks! theres nothing closer eh?
Old Nov 8, 2006 | 10:17 PM
There might be other shops but I'm not familiar with them. You might try posting in the Bay Area regional forum here on i-Club to see if other members know of a shop closer to you.
