E85 + 91 Octane
Old Oct 31, 2012 | 01:22 PM
esousa22's Avatar
^ this sounds promising and cautious. Definitely something to take note on
Old Oct 31, 2012 | 01:35 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
Originally Posted by XxSti05xX
I have a 91 and E85 map. Have only used my 91 map twice since I was tuned on E85. If I do run 91, I'll run down the 91 till its almost empty, I then fill up on E85 and switch to my e85 map but keep the boost down at 18psi(91 map boost level). Ill run at least 3 tanks of E85 before I even think of turning up the boost to 21psi and doing and hard pulls. Havent had any issues and car still runs strong.
I only average about 30-40 miles more per tank on 91 compared to E85. On 91 I'd go about week and half before filling up, E85 I usually fill up weekly
Sounds like it can be done!
Old Oct 31, 2012 | 02:44 PM
SkizzDawg's Avatar
Car Info: 2006 STI
Why not do a setup like the FLI one found here ?
Old Oct 31, 2012 | 02:59 PM
jdblock's Avatar
Car Info: 2004 STI
'Cause $1,600 ECU, plus other parts.
Old Oct 31, 2012 | 04:38 PM
SeaOfGreen's Avatar
Car Info: 2004 WW Evo RS
I was going to do this setup before I decided to sell my car. I have the Link ECU already, just need the sensor and have it all hooked up!
Old Oct 31, 2012 | 05:02 PM
04caliwrx's Avatar
I know that when I went to e85 I had so much 91 in my lines, injectors, and tank Ed thought I had something wrong with my car. Took about 3 tanks of e85 till it ran good and now it's smooth as butter I also would not change between 91 and e85 cause its very picky gas and likes to be 100% e85
Old Oct 31, 2012 | 07:17 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
I pumped 6 gallons of E85 on Friday in my tank. I'm tuned by ED on 91... The car feels a bit more responsive and sounds normal. Normally i dont put this much, I usually pump 2 gallons or so every other month to clean things out but I totally dazed out on the pump....I'd like to see a tune chime in and hear what they have to say
Old Nov 1, 2012 | 01:49 AM
DarkJuic3b0x's Avatar
Car Info: EQ Tuned * Corn Juiced '05 WRX
Yeah, me too.
I appreciate all the feedback.
Old Nov 1, 2012 | 03:49 AM
PROcede's Avatar
Car Info: 2015 FXT Stage II
Yo. Don't do that. Anything more then 2 e85 gallons to a full tank of 91 can really lean things out. I'd avoid boosting hard if you really have 6 gallons of e85 in the tank.
Old Nov 1, 2012 | 06:38 AM
jdblock's Avatar
Car Info: 2004 STI
You may wanna go inside and pay for 2 gallons so it automatically stops. Then top it off with 91.
Old Nov 1, 2012 | 03:02 PM
Haha, I've spaced out before while filling up. HAHA!
Old Nov 1, 2012 | 03:22 PM
silverbullet415's Avatar
just keep the e85 map on
Old Nov 2, 2012 | 03:15 AM
Bump. Hope Ed sees this soon and chimes in.
IDK, it's just something I've been thinking a lot about lately.
Old Nov 2, 2012 | 03:18 AM
It may not sound like a whole lotta extra miles, but when I was on 91, I'd average around 315-330 miles per tank...that was also when I didn't have as many mods...HAHA.
But still, one of the main reasons I'm thinking about also getting a 91 map is because there are more regular gas stations around as opposed to E85. If I need to go on a long drive/road trip, 91 is readily available versus E85.
Hmm......
Old Nov 2, 2012 | 10:29 AM
XxSti05xX's Avatar
Why not just get an economy map for E85. Lower boost levels and less timing.
