Dual Tips
Car Info: Silver 2002 WRX
Dual Tips
Ok, I have most of my exhaust planned out. TurboXS up pipe, down pipe, and super stealth turbo back exhaust. I want to keep my car a sleeper so what is the best cat back with dual tips?
Contact jack@ionperformance.com He has what you are looking for. You can get single or dual tips. You can shoose how loud you want it. I think even the size of the tips are customizable.
first off i thing you need an axle back, not a cat back
second, the stock axleback should be fine for the stealth back exhaust...that's why most people go with that set-up, so they can gain power and still appear to look stock.
if you're getting a stealth back exhaust it'll replace everything after the turbo to the rear axle. therfore, you'll have the Down-pipe and Mid-pipe covered. you can stick with the OEM axle back or maybe a different dual tip axle back.
Try Stromung, APS, MRT, and i think scoobysports too.
eric
I too have a turboXS turbo back exhaust.
good luck
eric
good luck
www.m2performance.com
Looks like stock and sounds incredible in person. Nice low rumble...not loud at all.
NemoSuby
Mar 25, 2012 10:49 AM
BoostBuddy.com
Engine and Drivetrain
Feb 20, 2007 07:02 PM
