Downpipe install question
Old Feb 27, 2003 | 07:04 PM
WRX34's Avatar
Car Info: 2002 WRX
Yeah, torque them down good and in the right order...(some say order doesn't matter though) And when cutting the heat shield just kinda cut it at an angle straight across...you'll see. I think there's like 6 bolts holding it on. Sometimes it might leak under boost until it gets warmed up too...but then again I'm in MI and it's cold as $hit. It'll sometimes fix itself. Good luck! I odered my HKS awhile back too....let me know how you like it and with what other exhaust/mods you have done!
WRX34
Old Feb 28, 2003 | 08:56 AM
Egan's Avatar
The heatshield will come off with something like 6 bolts. It only needs to be cut if the new downpipe interferes with it.
I don't know what the HKS looks like, but I had to do some slight trimming for my Stromung DP. When I switched to my Vishnu with divorced wastegate, I had to really hack up the heat shield. The top half is still in tact and does it's job shielding the IC. I now only have 2 bolts holding it on which are more than enough. They are the two that bolt into the bracket that is attached to two of the DP bolts on the top (you'll see).
I used tin snips. The heatshield is pretty thick in some spots.
Old Feb 28, 2003 | 09:17 AM
WRX34's Avatar
Car Info: 2002 WRX
Yeah...like I said before, you'll need to take of I believe 6 bolts on the heat shield...then use tin snips or heavy gauge metal shears and cut it...it'll be a pain but I think it's worth it! You don't have to put the heat shield on right away though, so if you're low on time just take it in at night and cut it then put it on the next day or whenever I think the HKS has a bellmouth so I'm pretty sure you can't just replace the heat shield in stock form. Prettyy much what wrXrated said too. Good luck!
WRX34
Old Feb 28, 2003 | 07:18 PM
Egan's Avatar
I did this a couple of weeks ago. It was my third time messing with the downpipe bolts (once for uppipe install, once for Stromung DP, then the Vishnu DP). I've got it down to about an hour in and out. Of course, then it takes me another hour to get the damn heatshield holes to line up so I can install the 2 bolts! That's where the expletives come in!
Old Mar 1, 2003 | 06:11 AM
misterx's Avatar
Car Info: MY 02 WRB WRX Wagon
I believe the torque spec for the downpipe bolts is 30 ft/lbs. When you install any exhaust component, it's best to go back after a bit and retorque. Mine started to leak a bit until I went back to retorque.
X
Old Mar 1, 2003 | 09:28 AM
Egan's Avatar
No 26 ft-lbs on all 7 bolts (5 DP-Turbo, 2 DP-3rd Cat). 22.4 ft-lbs at the tranny bolt. See attached:
edit: deleted attachment and linked to it in post below for better picture quality.
Old Mar 1, 2003 | 09:34 AM
Egan's Avatar
Sorry abouth the quality of the pic, but it's due to the size limitations on attachments. If anyone needs the unreduced file, email me.
I'll try and link to it from another site and see if that helps:
Old Mar 1, 2003 | 11:41 AM
AdoboUaReX's Avatar
wow thanks. that pic will come in handy.
Old Mar 2, 2003 | 10:40 AM
Egan's Avatar
I also have the pic for the front exhaust (uppipe, header) if anyone wants it.
Old Mar 2, 2003 | 09:58 PM
AdoboUaReX's Avatar
Sure. Can you post that too? I might try to take a crack at installing an uppipe if i get one. thanks.
