detonation between 4500-5200?
Old Jul 21, 2003 | 06:08 PM
BlkRx's Avatar
Car Info: 2004 Black Wrx
Have you brought it to the dealer you bought it from? This is definitly not normal, your in fact the first non-sti owner ive heard complain about an 04 pinging/detonating. I would go and complain, maybe your maps are out of wack for some reason or a sensor went bad. Have you tried reseting the ecu?
Old Jul 22, 2003 | 12:13 AM
hotrod's Avatar
audible knock not good
Audible knock on a turbocharged car is a bad bad thing. If its a new car, talk to your dealer, it should not be doing that on proper fuel.
On the 2002 wrx it took 17 - 18 psi, on an 85 degree day pulling a steep hill, to make 91 octane knock here at 5800 ft altitude and the ecu would immediately pull timing ( you'd hear 3 faint ticks and that is all).
Larry
Old Jul 22, 2003 | 11:49 AM
Subaruski42o's Avatar
Car Info: 98 RS
Um if i am correct there are two wire harnesses under your steering column. ONe is green the other is black. There is a male green and you have to plug that into the female green. Then there is a black male and you have to plug that into a black female. Turn the igniation but dont start the car hold down the throttle for 30 secds then start the car.
Drive around going faster then 13mph for 5 min or so. You should see the check engine light flash in 1/2 secd intervals. This should happen right away so keep driving for a few minutes.
With the WRX u might want to drive faster then 13mph maybe like 90mph to teach your car who is boss.
Your ECU is now reset
Old Jul 22, 2003 | 01:48 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
This is a known, and often-experienced issue. http://www.turboxs.com/turboxs_tech_101.htm
hioctane
Jun 8, 2007 08:59 PM
maharashii
Jul 25, 2003 06:10 PM
bspwest
Vendor Group Buys/Specials
Mar 20, 2003 04:58 PM
bspwest
Mar 20, 2003 04:28 PM
Camperguy
New England
Feb 3, 2003 01:04 PM
