Darn noise...
Old Jun 19, 2008 | 11:13 PM
Speeding101's Avatar
Car Info: gone
Darn noise...
So i did an up-pipe install today... i unbolted the intercooler, the air filter, then the turbo... i initially attempted to pull the up-pipe through the top of the engine bay... but i couldn't get the turbo off completely, so therefore i got frustrated and decided to try pulling out from the bottom of the motor... so i followed the instructions from scoobymods by perrin and ended up with it in and working... i also did a downpipe and cbe install and then a cobb ap stage II install... i got it all together and started the car... it runs and idles fine... i start to head down the road and there is a fluttering noise as i give it gas... it sounds like a card in the rim of a bike to make it sound cooler... but this isn't a pleasant sound... it doesn't make the noise when at idle or low RPM's or when i push the gas pedal 1/8 of the way in keeping it at a steady rpm... it does when in accel or decel... and is bad at lower rpm's when acceling or deceling... i also noticed that when i went for a drive before i uploaded my cobb it wasn't pulling as hard... so i took it back put it to stage II and i was pushing no more than 5.1psi... whats wrong?
Old Jun 19, 2008 | 11:39 PM
DemonPossessed's Avatar
Car Info: 05 wrx
To me it sounds like a post turbo leak. generally a preturbo leak will scream and a post turbo leak will flutter. however I used to have a very small uppipe leak and it ticked with I was building boost(but I would still hit target boost just fine).when I had a large uppipe leak it would scream. I've have a downpipe leak before also and it make a fluttering sound.
a sound clip would be great.
Old Jun 20, 2008 | 10:25 AM
Car Info: gone
will try...
Old Jun 20, 2008 | 10:29 AM
wrxisthebest's Avatar
i think ur restrictor pill is on the wrong side of the T
Old Jun 20, 2008 | 03:04 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
hmm is you BOV on tight? how are the gaskets? Maybe a Vaccum Leak?
Old Jun 20, 2008 | 03:12 PM
take the BOV off bro...
Old Jun 20, 2008 | 08:08 PM
Shazam321's Avatar
Im going to agree with DemonPossessed that you have a massive leak. Make sure all the surfaces are mated up. Check where the up-pipe connects to the manifold. Mine didn't want to mate up there correctly when i put it in.
He probably means BPV.
Old Jun 20, 2008 | 10:48 PM
Car Info: gone
my blow off valve is not on tight because one of the bolts roke and is inside my intercooler...then also ryan i tried that restrictor pill and i got absolutely no boost afterwards...
Old Jun 20, 2008 | 11:46 PM
SpADeZ_WRX's Avatar
Car Info: WRX
Wastegate flutter??
Old Jun 21, 2008 | 12:00 AM
VRT MBasile's Avatar
um, yeah, you're gonna want to go ahead and get that fixed
Old Jun 22, 2008 | 01:24 AM
Car Info: gone
well i fixed my boost problem... i totally redid the up-pipe and put it back together... i also fixed my intercooler... and now i get full boos... however i do feel like it might be a little laggy and i still have this nasty flutter from what sounds like within the turbo... IDK..
Old Jun 28, 2008 | 01:05 AM
freshrex's Avatar
Car Info: white 03 wrx
is it bad to drive around with an uppipe leak? is it possible to do permanent damage to the engine/turbo? i just got a huge leak and am driving mine in tomorrow should i tow it?
Old Jun 28, 2008 | 01:10 AM
a bad post-turbo leak will cause loss of low end torque
Old Jun 28, 2008 | 02:16 AM
MindzeyeWRX02's Avatar
Car Info: 2002-WRB-WRX-EJ257-stg2 / 2007-DGM-LGT-Ltd
When you did the initial install, did you put in new gaskets?
Old Sep 4, 2008 | 10:32 AM
Car Info: gone
Alright... im back with this same ?... cause i recently hit a deer and it did enough damage for me to be out of commision for a while... Yes i installed new gaskets and everything runs just fine... it is fluttering the worst when i am off the gas coasting in at high RPM's... i don't here the flutter when on the gas... only when off and when i push in the clutch and the motor starts to drop to an idle i here it the worst... the worst place to here it is behind me... all my gaskets are good and i have no flippin clue as to what is causing it....
kimchee
Nov 21, 2003 02:52 PM
Mrs. Xevious
Nov 9, 2003 09:00 AM
b_drift
Jan 29, 2003 03:19 PM
suby_dude
Jan 7, 2003 03:06 PM
