Compression in Stock Turbo Cars?
Old Jan 19, 2004 | 09:02 PM
mikesoob7's Avatar
Car Info: Stock 2001 WRX
I've been wondering why it is that manufacturers don't have a higher compression in the stock turbo-charged engines so as to give more low end power? I realize there's a detonation issue if the compression is set too high but couldn't you get just as much power out of a high compresssion, low boost engine as that of a low compression, high boost engine in the stock realm of the auto manufacturers?
I do understand tremendous amounts of boost can produce insane amounts of power but I'm just interested in something that manufactures could produce and stand behind on the warranty.
Mike
Old Jan 19, 2004 | 11:43 PM
Uncle Scotty's Avatar
Yeah...and if you ran race gas all the time.....
Old Jan 20, 2004 | 09:54 AM
ride5000's Avatar
Re: Compression in Stock Turbo Cars?
Mike
good question.
saab does somthing like that in their LPT cars. they're limited to about half a bar of boost.
ken
Old Jan 20, 2004 | 10:16 AM
nachomc's Avatar
Originally posted by OldGuy
High compression + Turbo, unless you use VERY expensive parts (Pistons, rods, heads, etc.) = Hand Grenade.
Old Jan 21, 2004 | 01:58 PM
ride5000's Avatar
tell that to all the guys successfully running turbo kits on formerly NA cars... subies, tegs, etc.
it certainly CAN be done, and done well... you just have to keep the boost down. act like an idiot and run too much, and THEN you have a hand grenade!
ken
Old Jan 21, 2004 | 02:12 PM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
Mostly a reliablilty issue with most auto makers. I agree with what ride5000 said it can be done but most manufactuers don't have high tolerance levels on their stock components and when running high compression and boost things are going to turn out bad.
Look at most camaro's 10:1 compression most superchargers are around 4-5 lbs kits. Were with mustangs around 9:1 compression most kits are around 6lbs. These are safe numbers not high performance.
GarageTech
Apr 18, 2003 03:20 PM
rayjle
Apr 5, 2003 12:17 AM
IS2Scooby
Mar 26, 2003 09:41 PM
bedarddc
Jan 5, 2003 10:50 AM
