cobb reflash
Old Dec 30, 2003 | 07:37 AM
wrx10404's Avatar
Car Info: 04' wrx
cobb reflash
i would like comments about the cobb reflash. seems too good to be true. 25hp for less than $400.
Old Dec 30, 2003 | 08:31 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
It's everything they say it is.
I have had stage 2 for a couple months, and I love it. Drives like a much faster stock car. In fact, I'm about to upgrade to their next staged map (VF34) because I liked stage 2 so much.
I put down ~215hp with it, a stock car dyno's at about 165-170 on this dyno.
It's the best single mod I've done.
Old Dec 30, 2003 | 08:42 AM
wrx10404's Avatar
Car Info: 04' wrx
mexican pizza, what other mods do you have?
you could pm me if you don't want to publish a shopping list.
Old Dec 30, 2003 | 09:56 AM
Slack's Avatar
Car Info: '02
Re: cobb reflash
Stage 1 was a great mod, I figure I got pretty close to their advertised 25whp (according to delta dash road dynos). I'd defineatly recommend it as a first mod. Power wise it is your best bang for your buck.
Old Dec 30, 2003 | 10:51 AM
nachomc's Avatar
I have stg1 - it's awesome. Makes the car SO much better.
Old Dec 30, 2003 | 11:02 AM
At the time it was gutted up, bosal DP, stock 3rd cat, Cobb catback, Samco IC-Y, K&N.
That was also before any learning took place, on a 100+ degree day. A guy with a well learned one, and an ice'd down IC put down mid 220's.
Old Dec 30, 2003 | 11:06 AM
Originally posted by blingbling
Is it like the stock computer in that everytime you mod it, you have to reset the computer or does it automatically adjust? Worse yet, do you need to get it re-reflashed if you mod?
Well you don't lose the reflash if you reset it. You lose the timing advance learning that has taken place since you last reset it.
As far as re-reflashing...with cobb they have a list of "smaller" mods that the ECU is capable of adapting for without additional mapping:
from http://www.cobbtuning.com/wrx/accessecu-faq.html:
Q. I have an up-pipe, and/or intercooler hoses, and/or a panel filter, and/or a BOV, and/or pulleys, etc. but I don’t see a map with those mods. What can I do?
A. Those types of modifications are within the AccessECU’s ability to adapt. Most of them (with the exception of the BOV) make a slight improvement in efficiency, but do not change the characteristics of the car enough to require reprogramming to work properly. If you add these types of parts later it might take the car a driving cycle or two to get the boost right on, but it will likely adapt unless the part makes a significant change such as a turbo-back. As stated above, if you have a question about your parts, let us know and we will help you choose the map that is right for you. That is much better than getting a wrong map, or thinking we do not have a map for your combo.
Turbos, injectors, new intercoolers, etc, should all be properly mapped for. They have maps for VF30/34 and STi injectors, and will soon have Stage 3 which includes an intercooler. Remember reflashes are only $20. And if you're curious, CALL COBB. I call them all the time to ask stupid questions, and they are amazingly patient and helpful.
Old Dec 30, 2003 | 11:21 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
the cobb reflashes are great.. cannot recommend them more
Old Dec 30, 2003 | 11:30 AM
ScoobyBoy's Avatar
does their reflash give you a fixed power increase? or will it all vary according to what you have. for example if one person has an invidia turbo back and another person has a txs turbo back, will both have the same power increase or will it vary?
Old Dec 30, 2003 | 11:40 AM
BanHammer™
it will vary to some degree. Cobb offers custom reflashes also if you have a lot of mods compaired to their stage 1 or stage 2 reflash
Old Dec 31, 2003 | 07:04 AM
wrx10404's Avatar
Car Info: 04' wrx
I appreciate the advice. COBB seems to be the way to go for me. I am going with the stage two. COBB is closed til 1/5/04.
Old Dec 31, 2003 | 07:05 AM
wrx10404's Avatar
Car Info: 04' wrx
Originally posted by batmanalan
the only dissadvantage is the downtime, but if you need an extra ecu i got one ill toss to you for 275 shipped, its a 2002 5 speed.
let me know,
alan
I am cool with the DT. Thanks for the offer though.
