chirp chirp
Old Dec 28, 2003 | 02:57 AM
ScoobyBoy's Avatar
Talking chirp chirp
i think ive got a bird stuck somewhere in my exhaust. i get this irratating chirp coming out of my muffler. everytime i rev the car i can hear the chirp. does anyone know what im talking about? it makes the sound at the end of the rev normally, but sometimes at cold start ups it makes the sound too, but very very faintly.
my only guesses to what it is, is the exhaust hangers, but i was applying pressure to two of them and it was still there.
anyone have a clue to what i should do?
im sorry if this has been covered before.
thanks
Old Dec 28, 2003 | 03:29 AM
mario's Avatar
HAHAHA. Check out your exhaust tips. There are these little holes that allow water to fall through.
Old Dec 28, 2003 | 03:41 AM
ScoobyBoy's Avatar
LOL you serious??? those damn two holes are what's causing the frickin chirps? that sucks...is there anyway to get rid of it?
Old Dec 28, 2003 | 04:17 AM
mario's Avatar
Yeah i know isn't it funny . Just plug up the holes w/ something that can take the heat.
Old Dec 28, 2003 | 06:53 AM
t-wrexxx's Avatar
I would get the car off the ground, start her up, and listen. Have someone rev it a little for you so you can stick your head under and get an idea of where its coming from.
Old Dec 28, 2003 | 09:32 AM
subiedon's Avatar
Car Info: SCBYDON
yeah, i think its those wholes on the exhaust tips as well that's creating that sound.
Old Dec 28, 2003 | 01:02 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
we have had another customer with this problem. Plug the holes
Old Dec 28, 2003 | 01:52 PM
Uncle Scotty's Avatar
Clean the area well with soap and water....let dry...put a piece of tape(duct tape works well) on the outside...apply some fast cure epoxy over the inside of the holes....let the epoxy cure....remove tape.....bird dead.
Old Dec 28, 2003 | 02:13 PM
my2003wrx's Avatar
get a catback, problem solved
:banana:
Old Dec 28, 2003 | 02:18 PM
ScoobyBoy's Avatar
bastah!!! that was my first thought when i saw you replied berry. thought you'd make some wise **** crack....
a catback costs so much, but i can always get a new axelback from you!
Old Dec 28, 2003 | 02:23 PM
my2003wrx's Avatar
did you try stuffing the holes with wood/cork? it won't damage the steel and it's cheap
:banana:
Old Dec 28, 2003 | 02:27 PM
ScoobyBoy's Avatar
i was thinking more along the lines of gum...
thanks all for the replies.
what did you use to plug the holes scott?
Old Dec 28, 2003 | 02:40 PM
my2003wrx's Avatar
gum melts, it's not going to work. but you already knew that didn't you? you could just weld the holes shut.
:banana:
Old Dec 28, 2003 | 11:13 PM
trebsrex's Avatar
Car Info: Old Brighton
Vic I got a custom axleback for sale (stealthy) used and bolts on to the stock one(pipe after axleback)
