check engine light catless dp w/ cel fix
Old Oct 4, 2007 | 04:53 PM
gnabgibeht's Avatar
Car Info: 2013 WRX Hatchback
i installed the helix v3 catless dp and installed the mechinical fix but the engine light still comes on and sometimes it backfires... any suggestion on what I should do.
thanks
-gnab.gib.eht
Old Oct 4, 2007 | 04:56 PM
pinofro's Avatar
Car Info: elcipse please dont make fun... thank you
do you have a bov?
Old Oct 4, 2007 | 05:38 PM
so steezy's Avatar
Car Info: *WiDe AnD LoW*
have u had a tune yet?
Old Oct 4, 2007 | 08:02 PM
gnabgibeht's Avatar
i do have a hks BOV and a hks hi power exhaust... you know how much tuning is? can someone plug in their accessport and map it and unmarry it to fix it?
Old Oct 25, 2007 | 05:28 PM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
thanks
-gnab.gib.eht
when you said fix did you mean w/ a spacer or resistor.....
Old Oct 25, 2007 | 05:44 PM
karis119's Avatar
Car Info: 05 STI
Tuning around the bay area seems to be anywhere from 200-300$ an hour. I don't think you can use the accessport like that, but I could be wrong. Your car is probably running very rich and you should look into a tune.
Old Oct 25, 2007 | 06:39 PM
BLUEJ20's Avatar
Car Info: 07 Car
get it tuned
Old Oct 25, 2007 | 10:05 PM
PeanutWRX's Avatar
Take off the BOV put back the stock one and get it tuned ASAP!
www.gstmotorsports.com
oh and An access port is married to an individual car and cannot be transfered without divorcing it from the owners car... Then when you install it onto yours it's only good for your car...
www.cobbtuning.com/
Old Oct 26, 2007 | 01:30 AM
03_Impreza_Al's Avatar
You should get the check engine light read. You should be fine with the mechanical fix and BOV.
Did you reset your ecu?
Old Oct 26, 2007 | 09:44 AM
ipozestu's Avatar
Car Info: Broken Subarus
Ricer....
Old Oct 31, 2007 | 11:08 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
getting it tuned is a good idea. but not for just installing a down pipe. keep you stock bov back on. reset ecu. and try again.
Old Oct 31, 2007 | 11:32 PM
VRT MBasile's Avatar
I apologize in advance
[rant]
oi veh "I put on a part, and I have a CEL, why do I have a CEL?"
why do you have a CEL? because youre car doesn't like something! The majority of us DO NOT have ESP and therefore don't know whats wrong with your car. Are you sure you put the mechanical fix in correctly? Did you install both parts at one time? Do we have any suggestions? Go to Kragen, borrow the code puller, and find out what the code is.
"Doctor....I have a pain, why?"
[/rant]
ageroxz
Oct 5, 2009 09:33 PM
barrrule
Aug 5, 2009 01:09 PM
WRXakaBooSTi
Jul 19, 2006 07:35 PM
esracer
Mar 16, 2004 11:56 AM
