Check Engine Light
Old Nov 12, 2003 | 10:43 AM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
Exclamation Check Engine Light
I fix my boost gauge and take the car out. The gauge works fine, but the CEL flashes. I immeadatly take the car home and call the dealership. This is what they found. Too Rich, Cat (no longer on car), misfire on all 4 cylinders, and exhaust gas temp. In the write up conclusion they stated: Possible engine running too rich causeing rich misfireing which causes enging light to flash. My mods are injen intake, Gruppe-S up pipe, HKS down, Apexi cat back, Fidanza flywheel, and ACT clutch. With that set up, wouldnt the car run too lean? I am lost and hope that someone can figure out what my car is doing.
Thanks,
Nick
Old Nov 12, 2003 | 11:04 AM
international B's Avatar
Chewwwwy
lightend flywheel wil lcause the car to " think" its misfiring. check your wire to the maf sensor, if that is loose it will cause all kinds of problems. if you get a mil eliminator that will sold the missing cat check engine light. also which egt code did you get? is it missing or just too high?
Old Nov 12, 2003 | 12:48 PM
I bought a cel eliminatior for the cat, but havnt put it on yet. This weekends project. The error codes that I got are as follows:
PO172 System too rich, PO420 Cat, PO301, PO302, PO303, PO304 missfire on all cylinders, and PO546 exhaust gas temp. Hope this helps. Is there anything I can do for the flywheel?
Nick
Old Nov 13, 2003 | 12:47 AM
Chewwwwy
nothing you can do for the flywheel other then remove it. the mil eliminator will take care of p0420, 1072 is probably a fluke if you are running stock engine management. put the mil eliminator in, reset your ecu and give it another shot.
fot the temp one, if it comes back, put a 2.2kohm resistor where the egt sensor plugs in, and that wil ltake care of it.
good luck!!
Old Nov 13, 2003 | 11:26 AM
Thanks, I will do that.
Nick
Old Nov 13, 2003 | 11:31 AM
Chewwwwy
let us know how it gos
Old Nov 23, 2003 | 04:38 PM
Put on the CEL fix and reset the computer. Checked the codes and it said that the exhaust temp was high. This was on friday. I drove the car friday, saturday, and sunday. On sunday night, I was driving home on the highway with the cruse on. The CEL light up again. WTF I am startin to get pissed. Anymore info?
Nick.
Old Nov 23, 2003 | 06:28 PM
philioWRXman's Avatar
Car Info: 1998 Chevy S10... lowww
maybe your fix came loose?
Old Nov 23, 2003 | 09:26 PM
Im gonna doubt it. It was soddered together, then a rubber shrink wrap cover was put on it. Would really have to work it to come loose.
Nick
Old Nov 25, 2003 | 05:45 PM
Checked the CEL. Another hot exhaust temp code. What is going on to cause that?
Nick
Old Nov 26, 2003 | 10:56 AM
I dont have any cats. How hard is it to check the plugs in out cars? Could I safely add like 2lbs of boost since I am runnin rich?
Nick
Old Nov 28, 2003 | 10:12 PM
GottaREX's Avatar
Car Info: 02 WRX
Hey guys, saw this thread and remembered my CEL on my car. I was wondering if I could rid of this damn thing. The CEL came up after, I forgot what code it was but it had to do with the bank 1 and 2 sensor having a low circuit. My only mods are gutted Uppipe, Invidia Turboback exhaust. I did the resistor mod for the uppipe and I also did the MIL eliminator fix for the downpipe. I know the MIL fix is properly installed coz my A/F gauge isn't bouncing up and down anymore like before. I've been drivin with the CEL light now for months and the car drives great. I just wish I could get rid of it though for a change. Any of you guys have ideas? Could this maybe be a faulty O2 sensor?
