cheapest cel fix
Old Jan 13, 2004 | 11:28 AM
WRXncrew's Avatar
Car Info: http://goo.gl/XpkO0b & '99 SF 'S'
Still going strong!
No CEL P0420 after installing the mechanical fix. It's been over 3000 miles now. This should work on '04' WRX and STi models.
Old Jan 13, 2004 | 11:32 AM
salaki's Avatar
Car Info: WRB STi - Red 92X
No CEL on '04 STi here.
Good fix! I like this mechanical much better than other fix that alter the OEM wiring.
GodSpeed's DP uses this method to somehow "hide" the 02 sensor from exhaust direct flow on their downpipes.
Hey... It works... $5 only......
Old Jan 13, 2004 | 02:09 PM
trebsrex's Avatar
Car Info: Old Brighton
Gonna save me $$$$
Old Jan 15, 2004 | 09:48 AM
trebsrex's Avatar
Did mine yesterday...Hopefully it gets rid of the cel Thanks again to the guy that made this mod work..
Old Jan 15, 2004 | 05:34 PM
blaznasn's Avatar
i've been using the non-fouler for a few hundred miles of highway and street, working fine. cost me 4 bucks
Old Jan 16, 2004 | 08:31 AM
subie2's Avatar
Godspeeds dp has an extension off where the O2 sensor goes. So the Sensor sits off the pipe just a little bit. It also has some cat material inserted in that extension so the sensor thinks its in a cat anyways.
I have the DP on my car as well.. The cat material in mine disengrated and after awhile it would throw a CEL.. so I contacted Dan at Godspeed and he said an easy fix is Aluminum foil over the sensor.. the reason it throws the code is because its getting too hot. So I put on some AF and its been working great ever since! Even passed inspection with it. He did offer to give me a new catted section for my DP and to pay to have it welded on at a shop down here, but the AF seems to be working great and I really dont want that downtime on my car. So two thumbs up for Dan at Godspeed!!
Chris
Old Jan 16, 2004 | 08:56 AM
salaki's Avatar
This fix w/ plug fouler is basically the same thing when you wrap the O2 sensor w/ Alumunium Foils.
It hides the sensor from sensoring a hotter exhaust gas.
I would think Alum foil tears really easy.
So IMHO, this fouler fix is the best so far that I have seen.
Old Jan 16, 2004 | 09:29 AM
WRXncrew's Avatar
My fix works best when you leave the small hole intact on the bottom and drill through the top non-fouler with the 1/2" drill bit. This keeps the O2 sensor from getting hot and throwing the CEL.
Old Jan 16, 2004 | 11:48 AM
salaki's Avatar
Indeed.
$5 and does not alter anything and will last forever.
The best out there. IMHO
Old Jan 20, 2004 | 06:49 PM
subie2's Avatar
well with the godspeed dp the O2 sensor is not in the direct path of exhaust flow so the AF method works just fine.
Old Apr 17, 2004 | 07:38 AM
Viking067's Avatar
Car Info: MY02, WRX Sti Prodrive
I got that light on mine.Made a similar to the pics here but the light is still on.
Do i have to reset the ECU or plug it into the dealers computer and reset it there?
Old Apr 17, 2004 | 07:57 AM
wrx10404's Avatar
Car Info: 04' wrx
Reset the ecu yourself. Take off the negative cable, pump the brakes a couple of times. Leave the car sit for maybe 30 min's. The ecu will reset. Relearn the ecu to your driving habits. There is a thread on here on how to do that. I just took it out and drove hard for about 45 mins. It took about a week for the ecu to get back to normal.
Old Apr 17, 2004 | 09:28 AM
Viking067's Avatar
Thank you :-)
Old Mar 14, 2005 | 08:45 PM
JAYSPEED's Avatar
Car Info: 02 Wagon
I have an 02 with a bosal DP so is leave the factory 3rd cat. You think the Mech fix will work in the Factory 02 location? I figured I could blow 5 bucks and try. I f Not I may make my own electronic fix. But not to keen on that.
Is anyone getting a rich or lean problem with there fixes???
Input please
Old Mar 17, 2005 | 08:55 AM
t3ch9's Avatar
Car Info: 2016 WRX
will i need to do a CEL fix if i get a helix catless dp?
