CEL error , HELP! :(
Old Jun 25, 2003 | 09:29 PM
mario's Avatar
Thumbs up
big donk just post on your local forums and ask if anyone has an OBD-II scanner to pull some codes for the cel, if that doesn't work bye one at a local autoparts store pretty expensive though. but im sure someone in your area has one. then when you get the code just ask here what it is. No need to go to the dealer ship and worry. good luck
Old Jun 26, 2003 | 04:50 AM
Mulder's Avatar
Car Info: 02 WRX WRB
You should definitely get it scanned, but it is most likely a P0420 catalyst inefficiency code caused by your catless downpipe. This code will come back after it is cleared, and the only way to get rid of it is to install one of the CEL "fixes" or "eliminators" that are sold for this purpose. If your car is an '02 or '03 the eliminators work fine, however if you have an '04 there will be a problem as they don't work on the '04s.
ImprezdGirl
Nov 6, 2009 02:59 PM
Big Donk
Jun 28, 2003 12:08 AM
Big Donk
Jun 27, 2003 11:05 PM
