Car shuddering problems
Old Jun 4, 2003 | 11:38 AM
Sounds more like hesitation or a misfire.
Old Jun 4, 2003 | 11:49 AM
suprawrx's Avatar
Car Info: 2002 IMPREZA WRX WAGON
MY CAR HAS shudder too when I start the engine cold. this shudder is happen often when the engine is cold.
Is it normal?
The hesitation will gone once the engine is warm up.
Old Jun 4, 2003 | 12:37 PM
DarriiffftaaHuy's Avatar
hesitation is normal when cold, but when the clutch & engine warm up it shouldnt be a problem anymore, unless you are just at too high of a gear for the speed you are going. if the hesitation doesnt go away when warmed up, then it may be a problem. have it checked out by a dealership and hope they're competent enough to find the problem.
Old Jun 6, 2003 | 03:57 PM
pmartell12's Avatar
Car Info: 02 Blue WRX
Boneamania - My dealership is replacing my clutch on Monday because I have cold chatter. I told the service rep to look up technical sernice bulletin 03-51-02. He got on the phone right away, and ordered my new clutch, another WRX in Sarnia has been through 3 transmissions because of CCC. I hope mine is fixed before it does any damage to the tranny.
Old Jun 6, 2003 | 05:36 PM
Originally posted by Boneamania
i wouldn't rely on a dealership. you know the warranty work doesn't have to be done by a dealership. other garages can do the work as long as SOA approves it. i wouldn't use a dealership...not after what i have been through with the famous "clutch shudder". its a known and recognized problem and they still won't fix it.
This is wrong. Only a Subaru dealer can perform work under warranty. You may be thinking of routine preventive maintenance, which can be done anywhere.
Old Jun 7, 2003 | 01:25 AM
EtchyLives's Avatar
Originally posted by eluminex
Does it feel like hesitation? My car hestitates between 2500 and 3000rpm with over half throttle.
This may be the car transitioning between open-loop and closed-loop boost. This is set to occur at 50% Throttle Position, stock. I still get it occasionally. It feels like the engine is stumbling, and the whole car shudders a bit. I get mine the worst after a reset, and then it flattens out, but occasionally it comes back to haunt me. Usually in 3rd gear, and normally when the car is not quite warmed up.
Old Jun 7, 2003 | 02:01 AM
suprawrx's Avatar
Should I go to the dealer to check it and tell them the 03-51-02 service bullertin for my cold clucth shudder?
