Can't figure out what's wrong.
Old Mar 15, 2012 | 01:53 PM
rsadarme's Avatar
Car Info: 2004 WRX Wagon
Talking Can't figure out what's wrong.
i have a 2004 wrx. I disconnected my battery to clean my filter to my short ram intake. When i reattached the batter i took my car for a drive. Normally my intake will make my throw my CEL on, but to me that's normal. Currently my CEL is not on and my car is running a bit funny. I idle below 1000 and i was wondering if thats normal. There have been times where my car wouldn't start in the morning and usually wiggling my battery cable will do the trick. I can also tell that i'm lacking in a little bit of power. I'm wondering if it could be my battery or my alternator or something totally different. Any ideas???
Old Mar 16, 2012 | 11:06 AM
MarvZz's Avatar
Car Info: 03 wrx
seeing that no one else has replied to you... you shoudn't be able to wiggle the battery cable if its tight, so tighten that up. i dont really know, but might be your car relearning the fuel trims? drive it around a while and see if that helps.
Old Mar 19, 2012 | 04:02 AM
JASC's Avatar
Car Info: 2003 WRX
Either you have reset your ECU, and your running unfamiliar because it has finally recognized that you in fact have a short ram, which can be sorted out through a tune. The other thing that might be wrong is you have a leak coming from your short ram or somewhere in your Turbo inlet pipe. Check those aswell. Also, do you have an aftermarket BOV? VTA's can cause a drop in rpms at idle (typically anywhere from 800-900). If you can, write up a list of some mods so we have a full understanding of what else the issue could be.
Old Mar 28, 2012 | 07:51 PM
rsadarme's Avatar
I also have a highflow helix DP and a megan racing catback
Old Mar 28, 2012 | 07:59 PM
johndabrit's Avatar
Da Brit.
Did you plug your mag back in? Is the maf upside down? Are you protuned?
Old Mar 28, 2012 | 08:13 PM
DabiDa's Avatar
Car Info: 2002 wrx
As stated make sure that battery clamp is tight.Also do you have a tune with that downpipe?My rpm is not at 1k at idle i think i idle at 700 or 500 .Crap ill check it out tonight when i go grab some dinner to confirm.Also if your battery keeps going dead after charge, that would indicate a alternator may be needed
Old Mar 29, 2012 | 08:14 AM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
How long have you had this car?
Are you tuned for the parts you are running?
are you aware its a Subaru not a Honda?
Not to be rude I made alot of the same mistakes you have I.E. intake, exhaust. Not knowing you need to be tuned for such things with these cars.
If your car is acting different after disconnecting the battery it is probably because you reset the learning in the ECU. If you are in fact tuned drive it like you stole it, and it will work itself out.
If you are not tuned. Call a local shop, and get tuned.
Old Mar 29, 2012 | 08:31 AM
Volkey's Avatar
Car Info: A Dirty Car
These are very important details.
Old Mar 29, 2012 | 12:37 PM
Shayhan27's Avatar
LOL we need to be friends.
Old Mar 29, 2012 | 08:07 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
Cobb Ap, Protune, Os, Stock Map?
Old Mar 29, 2012 | 08:22 PM
glenspen's Avatar
Car Info: 05 WRX
It's sounding like we have a modder who isn't getting the car tuned for the parts being fitted.
OP - Go speak to a tuner
RLLYRCR
Aug 26, 2010 08:45 AM
ryball
Jun 19, 2005 04:03 PM
IS2Scooby
Jun 18, 2003 08:54 PM
Zoeb2s
Jan 24, 2003 01:04 PM
