Boost Fluctuation. HELP NEEDED
Old Jun 15, 2014 | 08:11 PM
Xlagman92's Avatar
Car Info: 2002 subaru wrx
Alright guys so im on a ots map from v1 cobb stage 2 tuned. car is fully stock except turboback of course... 16psi is my target boost and i noticed my boost spikes up to 18-20 psis and then falls down to 11-14 psis and then bak up, basically bouncing back and forth from 14-18 psis all the way through redline. I checked my OEM boost solenoid and it seems fine. Plugging in the battery from the car and making sure it opens and closes, i also cleaned it with maf cleaner. Any help guys? Would u guess that the wastegate has too much load causing boost spike? should i try using a stage 2 "low wastegate map"
thanks i-club!
Old Jun 15, 2014 | 08:45 PM
silverbullet415's Avatar
so this all started when you went stage 2?
Old Jun 16, 2014 | 03:07 PM
Xlagman92's Avatar
yep. I had another question, so the "T" connector for my turbo hoses broke, and I replaced it with a "Y" connector, would that matter as well?
Old Jun 16, 2014 | 04:04 PM
Heedz's Avatar
Nobody likes the tuna here
Nope doesn't matter as long as inner diameter is the same.
Old Jun 16, 2014 | 10:39 PM
DabiDa's Avatar
Car Info: 2002 wrx
I had same issue first time i went stage 2 Cobb map had same symptoms bought a used 05+ ebcs worked fine then return to stock for smog and same issue all over again,I finally just picked up a hallman pro rx mbc and went open source have been working great ever since.The ebcs will sound fine when in test mode and will work fine at stock levels but def recommend to upgrade it i think Cobb now has 3 port ebcs maps that you can just plug in and flash the map and good to go
Here is a link to the map notes from Cobb
https://cobb.app.box.com/02-05-wrx-map-notes
Old Aug 26, 2014 | 10:03 PM
Xlagman92's Avatar
sorry for late update!! but yup!! it was definitely the stock ebc! I switched to GM boost controller and the problem went away!!
Old Oct 11, 2014 | 12:55 PM
DabiDa's Avatar
Car Info: 2002 wrx
Good to hear glad it worked out
antjariv
Apr 2, 2015 04:27 PM
Europa
Mar 13, 2011 02:23 PM
jahl7787
48
Sep 9, 2006 01:45 PM
Chrisnonstop
Jan 3, 2006 07:52 PM
sunbum
Nov 9, 2004 03:00 AM
