boost controller questions
Old Nov 2, 2004 | 10:26 PM
dose84's Avatar
i got a lightly modded 02 wrx and am thinking about installing a ebc. what i was wondering is how it affects the air/ fuel mixture at partial throttle. i think i heard somewhere that putting one on leans it out unless your at WOT. is this true? i tried searching the forums for an answer but couldnt find it. also what do you guys think, hks, blitz, greddy?
Old Nov 2, 2004 | 10:48 PM
RussB's Avatar
Car Info: $200,000 sports car
it can cause you to run lean. the ecu has a closed loop fuel mode and an open loop mode. while in closed loop it will run around 14.7:1 afr. at open loop it will run closer to 10:1 afr. by running an ebc, you can and probably will make more boost than is safe while in the closed loop fuel mode. for the price of an MBC + install, you are very close to the price of an EcuTek reflash or a Cobb Accessport. both of those are much more comprehensive than an ebc.
if you are set on running an ebc, check out the device detailed in this thread: https://www.i-club.com/forums/bay-area-15/introducing-ed-vaus-here-i-club-he-can-help-those-you-mbcs-75849/
basically it will send your ecu into open loop fuel when your boost gets high enough to warrant it.
Old Nov 2, 2004 | 11:08 PM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
if your not going Utec or reflash then go with the Apexi AVC-R ebc. One of the best ebc's on the market.
Old Nov 3, 2004 | 11:18 AM
dose84's Avatar
thanks for the info guys! guess i got alot more research to do into this
Old Nov 4, 2004 | 11:55 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
if you are set on running an ebc, check out the device detailed in this thread: https://www.i-club.com/forums/showthread.php?t=75849
Spot on advice... including my OLM device .
Thanks Russ!
-- Ed
mystilexzero
Sep 28, 2015 12:37 AM
RavSpec
Vendor Group Buys/Specials
Oct 4, 2004 12:03 PM
RavSpec
Sep 9, 2004 10:42 AM
RavSpec
Aug 25, 2004 03:26 PM
Top
