boost controller
Old Mar 9, 2004 | 05:21 PM
nerrad5's Avatar
Car Info: 02 WRX WRB 4EAT VF34 Kit w/AP
The word is to not exceed 16 psi on a stock engine. I have a DNA MBC and 4EAT tranny with max boost in fourth at about 15.5 psi (Between .1 and .11 Mpa) And dont forget about PT/FB (partial throttle/full boost) Without the stock boost controller to watch the pressure, it doesnt know how much to richen or lean the fuel. Except when your WOT then its ok. Just make sure you get a boost gauge. And dont go over 7psi unless your floored. Im soon to get a Vishnu dyno tune which will take care of my PT/FB. Then no more having to watchg the boost gauge.
Hope this helps
Darren
Old Mar 9, 2004 | 07:29 PM
Damaged Goods's Avatar
Car Info: 04 wrx
im running 16lbs on mine, with a up pipe and turbo back. Its sorta a pain in the @** because boost changes if it gets colder. I accidentally overboosted the other night when it got cold and hit fuel cut. Im happy with the performance improvement (13.58 1/4 mile) but if i did it again i would save up for an electronic boost controller because it adjusts itself and holds the right boost, and is easily adjustable from the drivers compartment.
Old Mar 10, 2004 | 05:53 AM
Car Info: 04 wrx
Originally posted by BAYSIC REX
so you can have your car dyno tuned with just the boost contoller? will it be able to make a diffrance or are you getting the
whole ecu reflashed? thanks for the info guys..
how do you know what the fuel cut is?
your car goes "vroooooom vrooooooommmmm then it sorta pops, you lose power and your CEL comes on.
I dont know about the other question, i was sorta wondering the same thing
Old Mar 10, 2004 | 06:36 PM
nerrad5's Avatar
Yes you can. With just a MBC though with a dyno tune you wont see/feel much difference. Youll need to free up exhaust and other mods to get the benefit of a dyno tune. I finished all my mods so now its time to tune the chip. My mods are:
MBC set to 15.5
Greddy Evo Catback
Vishnu 321 Uppipe
Samco IC hoses
Intake silencer removed
I talked to vishnu and I dont have to do a reflash. I guess thats just if you have a whole bunch of mods. For me they have preset maps they will just install and fine tune.
You'll know when you hit fuel cut. IIRC it is set at 17 psi. Basically you just stop going. It feels like when you let off the gas quickly and the CEL comes on. Ive done it once on a cold morning. Thats when I set my boost from 16 to 15.5. But within a day or so if normal driving and no more overboosting the CEL will clear itself. At least mine has.
Old Mar 11, 2004 | 05:26 PM
nerrad5's Avatar
If you are getting the gauge from subaru (mine is) it is in Mpa. So basically .05 = 7.35 psi and .1 = 14.7 psi or 1 atmosphere. You want the needle to peak at ( in 5th gear on a 5mt) between .1 and .11. no more then .11 max.
Im not sure what they change on a dyno tune. I was told they have new maps (fuel settings etc) to make the best power for your mods. For Example, If you free up your exhaust the existing maps wont really know what to do with it. You will get some performance increase, but just what the stock map will allow. You put in a new map with what to do with the new increase in flow and you will definitley get more power/torque.
I will be going to vishnu in about a month. I will let you know when I am going. If you are ready to remap yours, you could meet me up there. The price is (last time i talked to them)
$90 to use the dyno
$200 per hour of tuning
said it usually takes about an hour. so figure about $300 to $400
If you are going to use an MBC, be sure to tell them to install the map to fix the PT/FB issue.
Never mind about meeting. I had a brain fart and thought I was in my regional forum. Oops
Old Mar 14, 2004 | 05:30 PM
nerrad5's Avatar
Im not to familiar with the profec b so Icant help you there. But we are planning another meet in about a month. Keep an eye out the the bay area forums and i will let you know. Maybe someone else familiar with the profec b can jump in and help.
mystilexzero
Sep 28, 2015 12:37 AM
RavSpec
Vendor Group Buys/Specials
Oct 4, 2004 12:03 PM
RavSpec
Sep 9, 2004 10:42 AM
RavSpec
Aug 25, 2004 03:26 PM
XwrxX
Dec 17, 2002 07:14 AM
