Boost ???????????
Old Jan 19, 2003 | 10:49 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Not true. Stock can be anywhere near 13psi to a spike of 15psi. Your car is normal if it's bone stock.
Old Jan 20, 2003 | 01:48 PM
ScoobyBoy's Avatar
i agree with teiva boy on the numbers. the boost ranges, theres not really a set number.
Old Jan 20, 2003 | 10:00 PM
teiva-boy's Avatar
How are you measuring this? Do a 3rd gear or 4th gear pull and you'll see the true(max) boost levels. If your only doing 1st or 2nd, then you wont see full boost. If all else fails, get a turbo back! That will raise your boost about 2psi without actually touching the boost controller.
Old Jan 22, 2003 | 10:56 AM
mmboost's Avatar
Cobra's got it down. I second all he said.
Also, for the record, Subaru says stock boost is 14.2 PSI. I was running close to 13. Some people were running 15.
From my experience, don't waste your time with bleeder or 3/16 mods or even MBCs. Just get an electronic boost controller if you can afford it. Especially at higher elevations. Since you are more prone to overboost at higher elevations (the need for more O2 makes you greedy ), having an electronically controlled quality solenoid-based limiter will do you worlds of good. I recommend the Blitz DSBC Spec-R, cost vs. performance is excellent.
jason
