Blitz Axelback Squeak
Anyone with only an axelback experiencing sqeaking after spirited driving? I have a Blitz Nur Spec axelback that I plan to eventually mate up with a TXS stealthback. In the meantime I seem to develop this temperature dependent squeak after freeway driving. The Blitz has slotted mounting holes and after the exhaust heats it moves from side to side causing embarrassing squeaking. This seems to happen no matter what the bolts are torqued to. I would really appreciate any ideas to prevent this until I can purchase the remainder of the exhaust system and have it all welded together.
thanks, Brian
thanks, Brian
i know what you mean about embarrassing squeaking. i have a cat back blitz exhaust and had the same problem. what you need is new exhaust hangers. i have kartboy exhaust hangers and it stopped squeaks in my car. they run about 35 to 40 a set of 4 hangers. good luck. peace
Check your distance from exhuast hangars to the sway bar. I ended up wrapping old green water hose around the exhaust hangar to stop the annoying rubbing with the sway bar. No more squeaks.
MrMakesItRain
Jun 12, 2008 02:14 AM
hokusai
Dec 4, 2003 08:21 AM
