Best Up pipe available
Old Nov 25, 2002 | 02:43 PM
Choku Dori's Avatar
Car Info: Corvette Z51
What about Japanese brands like HKS? Just curious about their uppipes, since I'm sort of a JDM ****
Old Nov 25, 2002 | 03:42 PM
JunGdB's Avatar
Car Info: White GDA
huh....
How about HKS up-pipe? i saw it sale on www.hksusa.com website! never know they have it !
Old Nov 25, 2002 | 03:46 PM
1fastGC's Avatar
Car Info: Evolution VIII
currently using MRT uppipe w/ flex joint. its been on the car for almost 10k miles. no leaks. power gain is tremendous.
Old Nov 25, 2002 | 04:14 PM
En3D's Avatar
I think when buying an uppipe the most important thing to consider is the diameter of the pipe. There is a reason why Subaru made theirs that size. With that said, Vishnu and the catless Subaru JDM pipes are the best. Shiv makes his the same diameter as the stock pipes. And I would avoid uppipes with flex joints.
Old Nov 25, 2002 | 05:00 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Yah what whack-job's would put an unreliable flex joint in the uppipe sheesh! (Stock!?@#?!#)
The absolute best bang for your buck is to gut your factory uppipe and re-install it. The Subaru engineers are no dummies.
Paying $300 for an aftermarket pipe is insane. At least when you have somewhat limited funds to pipe into the car.
I just paid $80 for a gutted stock pipe, and am about to pay 120 for the install. It will fit like stock, take the stock EGT sensor, look like stock, blah blah blah.
IBT-angry-responses-from-people-who-bought-'spensive-uppipes
-=eric
Old Nov 25, 2002 | 05:08 PM
Originally posted by V6turboTA
IIt is very restrictive for a few reasons.
Could you elaborate? From everything I've read...you don't want to make the uppipe diameter larger (slowing flow before turbo = bad thing).
I understand that if you want a bigger turbo or a wideband bung...then aftermarket is the way to go. But just the fact that I won't have warranty issues, or issues with that EGT bung falling out is basically what I was after.
Old Nov 25, 2002 | 06:06 PM
Choku Dori's Avatar
Any sources for Subaru JDM catless up pipes? They sound quite good to me
Old Nov 25, 2002 | 06:07 PM
En3D's Avatar
"Could you elaborate? From everything I've read...you don't want to make the uppipe diameter larger (slowing flow before turbo = bad thing)."
exactly. velocity is your friend. It's not an exhaust. The only thing that I think is bad about a gutted stock uppipe is turbulance.
So your gutted uppipe, is the inside smooth or is there a larger diameter where the cat used to be?
Old Nov 25, 2002 | 07:25 PM
big sky's Avatar
Car Info: 04 GGA+
The STi uppipe has a flex joint in it as does the oe piece, this is one of the reasons you hear few if any complaints of leaking. This was my main impetus for selecting the STi pipe (I had heard enough horror stories about leaks). One can argue the virtues of pipe diameter and flow, but 90+% of gains w/ a uppipe are the simple removal of the cat, this includes the faster spool.
Old Nov 25, 2002 | 07:46 PM
Best I can do. (Actually the best that sr20det91 could do after he finished gutting it for me).
http://photos.imageevent.com/olivare...tted%20002.jpg
http://photos.imageevent.com/olivare...tted%20003.jpg
Might be a bit of turbulence. For $80, it don't bother me a bit!
