best streetable turbo...
Old Jan 7, 2004 | 09:01 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
been looking for a while into what turbo to get....
i would like moderate boost in HP but don't want to get a lot of lag....any recommendations...
Old Jan 7, 2004 | 09:44 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
deadbolt ported stock turbo, or a VF23/24.
i have a deadbolt unit, and it works quite well. boost comes on nice and early, enough so that i can often get away with using second gear in hairpins that i used to have to downshift into first for. without upping boost, you won't see much of an increase in peak hp, but you'll get a much broader powerband. you can run this with the stock ecu and injectors easily (i am right now), but to get the most out of it you'd need a reflash and STi injectors.
the vf23/24 are two of the quickest spooling VF series turbos, they'll spool just a bit later than a stock turbo. deadbolt can port these too, to the tune of like $200. i've heard that you can run these with he stock fuel system, but i don't think i would. you'll get more peak power here, but i don't know as much about the width of the powerband.
Old Jan 7, 2004 | 09:52 PM
Daredevil's Avatar
the vf30/34 is also really streetable
Old Jan 7, 2004 | 09:56 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
i was looking into deadbolt....thanks for the info
Old Jan 7, 2004 | 10:11 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
VF34 is my favorite performer for the all round WRX. Plenty of pull around town and nice performer at the track/strip.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Jan 8, 2004 | 01:14 AM
Uncle Scotty's Avatar
What ^^^^he said.... if ya get your TD04 P&P'd, get a 7° clip, too Mine ROCKS...I gave a guy a ride tonite, and he couldn't believe it was the stock turbo...I had to show him
If you could find a nice, cheap, new VF23 to have P&P'd THAT would a real good upgrade, I should think, too You'd need injectors, a pump and EM for that one, though.
Old Jan 8, 2004 | 10:28 AM
i'd thought about going with a P&P VF24 before i bought the deadbolt TD04. i didn't have the cash to throw down on injectors, pump and EM all at once on top of the turbo. if i had, thats what i'd be running. from all the research that i did, that combo should give you one hell of a bump in midrange hp and torque.
Old Jan 8, 2004 | 11:14 AM
when you get it installed, be sure to post some info on it. i'd be curious as to when your P&P VF34 spools, and what the powerband looks like.
Old Jan 8, 2004 | 08:14 PM
MikalsWRX's Avatar
Sorry for the stupid question but Im also in the market for a turbo. i was thinking vf34. What is Deadbolt? A company? P&P is port and Polish ?and what is a 7 degree clip. Thanks again and sorry. laters Mikal
Old Jan 8, 2004 | 08:57 PM
Daredevil's Avatar
deadbotl is a company that ports and polish's turbo's
as far as the 7 degree clip, i've no idea
Old Jan 8, 2004 | 08:59 PM
Former Sponsor
Clipping turbo's is generally not a good thing to do it may add some increased flow potiential but will take away from the overal efficeincy causing lag.
Mike
(510) 487-4447
Old Jan 8, 2004 | 09:00 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
VF35.
Old Jan 8, 2004 | 11:07 PM
No lag here...The P&P more(far more) than makes up for the bit of clip I almost never wait for boost, and it does a great job of holding boost a lot better towards redline which is the best benifite of the clip.
A big, broad power band is what I've got
Old Jan 8, 2004 | 11:45 PM
Former Sponsor
Glad it works for you, a better actuator would have held the boost till redline though then you would get the benifits of the porting not countering the ineffiecency of clipping.
Mike
(510) 487-4447
