best bov for a rex?
Old Jan 1, 2004 | 03:42 AM
iLoqin's Avatar
Car Info: Nadda
A little research on the forums? There are many opinions about each kind if you search this forum.
Old Jan 1, 2004 | 05:12 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Best for noise? Whatever makes you happy.
Best for performance and the engine? The stock bypass valve that is already there
Old Jan 1, 2004 | 10:38 AM
eclipse0001's Avatar
Car Info: 02 WRX
If you want one, I would get the GFB 50/50 bov because it is only 50% atmospheric. It has a nice sound. If you want the best sounding bov, get the Turbo XS RFL. All in all you dont need one though. The stock setup is fine. Do the silencer mod and you can hear the factory one when you let off the gas pedal at full boost. a 100% atmospheric one will give you a check engine light and your car will run rich. For the money you would shell out on the bov, you could save about 100 more bucks and have something worth the money like a reflash. This is just my opinion though.
Opinions are like *******s everyone has one.
Old Jan 1, 2004 | 01:05 PM
oldmansan's Avatar
Does your stock
bov have a problem? Unless you have a FMIC or a problem with the stock bov, I see no reason to spend money on an aftermarket bov. Spend money on something else that might actually give you performance gains.
San
Old Jan 1, 2004 | 01:12 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
I think people want to replace the BOV just for the sound. If its an actual performance reason, then what oldmansan said is 100% correct. The stock BOV has no problems. If you run more boost then what it can handle, then by crushing the top of it will solve that without the need of replacing the unit.
San
Old Jan 1, 2004 | 03:57 PM
KmanRuffian's Avatar
Car Info: 2002 White WRX Wagon (WWW)
Why don't they just buy a little speaker that plays the blow-off sound everytime you shift? Bet it would be cheaper and wouldn't cause any problems or void your warranty... Hell you could play the sound of a V8 or even a V12 engine from it! Or better yet and F1 car! Bet that would make you go fast...
Old Jan 1, 2004 | 04:31 PM
t-wrexxx's Avatar
I was in Pep Boys the other day and saw this thing that you stick under your hood that makes (as the box stated) "that turbo noise." Maybe i'll buy one and people will think I have a twin turbo setup....
Old Jan 1, 2004 | 04:36 PM
kspek's Avatar
Car Info: non subarus
yeah if you want it for sound get a 100% atmo one if you want performance keep your stock one or get a 50/50 one
Old Jan 1, 2004 | 05:26 PM
Daredevil's Avatar
actually
they have that for honda's....
its a speaker that goes under your hood, and it makes the noise a BOV would make
so lame
Old Jan 1, 2004 | 05:32 PM
Salty's Avatar
Why get a 50/50 when you can get the best of both worlds and get a 0/100 GFB stealth? Long trip with the wife? switch it to 100% recirc which is what the OEM valve is. Going to a meet, want to show of on friday night? switch it to 100% atom blow off or anywhere in between!
simple! turn of the wrist and your adjustments are infinite!
Eric
Old Jan 1, 2004 | 06:55 PM
Re: Does your stock
San
get a sway bar
Old Jan 1, 2004 | 08:05 PM
Re: Re: Does your stock
Originally posted by sigma pi
get a sway bar
Amen.
Old Jan 1, 2004 | 08:43 PM
Car Info: 02 WRX
yeah i agree the re92's are baaaaad. however they seem nice in the snow. My plan for wheels and tires are to get some nice wheels and some sticky tires for summer and my stockers with some blizzaks then ill be unstoppable!!!! IMO, I would get a rear sway bar or a reflash (the reflash is depending on the mods you already have done).
