Backfire
Old Oct 9, 2003 | 07:25 PM
Uncle Scotty's Avatar
If you have an aftermarket 'BOV' venting to atmosphere, then you will blow fireballs, sometimes.
Venting to atmosphere causes a over-rich condition on shifting and excess fuel goes 'BOOM'....
If no BOV, then tuning is in order....Shouldn't hurt to be a bit rich..better than too lean.
Old Oct 11, 2003 | 12:04 AM
You can't vent 100% to the atmosphere and NOT overfuel...thus causing the fireballs. Some 'BOV's" are 'tuneable' and allow the amount vented to be adjusted. This allows a 'happy medium' in venting and fueling. GFB makes one and Worxtuning makes another, there may be others but I don't know.
IMHO, the ONLY reason to use an aftermarket 'BOV' is if you HAVE to because you are using a FMIC or you are running over ~20psi. boost and NEED one.
hashiriya
Jan 23, 2004 01:19 AM
navwrx
18
Sep 17, 2003 02:16 AM
timl
23
May 24, 2003 11:39 PM
awns729
May 10, 2003 09:33 PM
kaneda3
Mar 23, 2003 01:50 PM
