Avcs
Old Jan 15, 2004 | 12:20 AM
international B's Avatar
Chewwwwy
avcs is on the jdm sti head's as well as the usdm sti heads. you will need some addtional wires, as well as an ecu equipped with avcs to run it.
Old Jan 15, 2004 | 06:10 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
What is AVCS?
Old Jan 15, 2004 | 09:13 AM
whitelegacy98's Avatar
USDM = United States Domestic Market
JDM = Japanese Domestic Market
Old Jan 15, 2004 | 10:05 AM
mr_yellow's Avatar
AVCS is subaru's version of variable valve timing, like honda's VTEC or toyota's VVTi
Old Jan 15, 2004 | 11:06 AM
awns729's Avatar
Car Info: want a WRX
Its not honda's vtec. hondas vtec has a different set of cam lobes take over after a certain rpm...AVSC constantly regulates valve lift and timing
Old Jan 15, 2004 | 01:38 PM
theworx's Avatar
I assume it help with problems such as low end torque and high end flow. How much of a difference does it really make?
Old Jan 15, 2004 | 04:45 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Incorrect.
AVCS only changes cam timing. Not valve lift.
Old Jan 15, 2004 | 04:49 PM
awns729's Avatar
Sorry, my mistake. But besides that avcs is constantly regulating cam timing and vtec just changes over to a diff set of cam lobes at a certain rpm...howstuffworks.com has a lot of info on vtecs if anyone cares...
Old Jan 15, 2004 | 04:55 PM
Imprezer's Avatar
Admin v2.0
Yep. AVCS is dynamic system. It uses individual cam angle sensors and duty selenoids to regulate the oil pressure that drives the cam timing adjustment mechanism.
Old Jan 15, 2004 | 05:07 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
AVCS = Active Valve Control System and is constantly changing to suit the engine. It only changes cam timing not valve lift.
Old Jan 15, 2004 | 11:32 PM
MJU1983's Avatar
Car Info: 06 Armada, 03 WRX, 05 STi(sold), 05 Vette (sold)
Originally posted by imprezasti
wat site sells this product?
your local subaru dealer
