aps tmic broke a/c
Old Jul 21, 2003 | 08:39 PM
Fantabulous's Avatar
whats wrong with the aps tmic? i was thinking about getting one.. i hear they make the biggest one that will fit under your hood. Well about your a/c lines... i would wrap them with some kind of heat resistant wrap or try to bent them back more if possible. the tmic gets that hot? maybe you should invest in a water spray kit. also does the intercooler come with a y connector? and how much you pay for it?
Old Jul 22, 2003 | 12:27 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
No matter what intercooler you would have gone with, almost all require you to bend the AC lines a tad and/or put in a piece of rubber to prevent what happened to you.
In a normal world, when you fit something and there is a close tolerance to another piece, you either adjust it, or you move it.
Old Jul 23, 2003 | 01:13 PM
Egan's Avatar
Yes, the A/C rubbed against the TMIC and over time a hole developed. You can prevent this by cutting a small piece of hose open and wrapping it around the A/C line as insulation.
You should be able to run a TMIC without a splitter if need be. I don't see how it could cause deformities in the scoop. The TMIC should not be getting that hot, unless you ahve some serious problems. Think of it this way, if it was hot enough to melt your scoop, then a whole lot of people would be having problems with stock/STi rubber seals melting to their TMIC's (some larger IC's use the STi seals).
Old Jul 24, 2003 | 07:02 PM
mrazntre's Avatar
Car Info: MY03 WRX Wagon
probably cheap plastic.
Old Aug 1, 2003 | 10:54 AM
fastnoypi's Avatar
very unusual..i have a ver1 APS topmount and i have plenty of clearance in the back. Only problem i had was clearance of my coolant jacket..i had to bend it out of the way of the mounting bracket
LICmotorsports
Sep 17, 2012 03:32 PM
wrx-sleeper
Apr 11, 2007 12:18 PM
ewright
20
Oct 8, 2005 11:32 AM
BDR
Apr 7, 2004 04:28 PM
