APS Short Ram Intake
Old Jul 16, 2004 | 07:56 PM
blue blurr's Avatar
make a review in the review section https://www.i-club.com/reviews/showcat.php?cat=22
Old Jul 16, 2004 | 07:59 PM
OLMEK's Avatar
OT Big Kahuna
From: Harder to grasp than Science & Math to pale swined cavemen who don't practice and live backwards.
Car Info: Salty-Killah
Smile
Thanks for the recommendation. The sluggishness you're experiencing is a common result of applying this modification.
Some shops can do mapping for quite a few intakes that are predictable. The car may not be as smooth or might miss out on some power since they have to tune it even more conservatively with most of the intakes, but it will be safe, and run better than the factory ECU. They could make a map for it that would make sure that your wrex runs rich rather than lean, but the benefits would be far less than that if you just removed the intake and used the factory unit.
Also, even if the intake is advertised as not needing correction, causing no errors, or factory specifications, let the shop know unless decaled. This is not the case on the intakes that we have tuned that make this claim, they do require correction. Just because the piping that the sensor sits in is the exact factory spec does not mean that there is no turbulence to throw the sensor off.
In the end if you want the smoothest running car use the factory air box. If you want the noise and slightly better spool-up, remove the silencer in the fenderwell and toss a panel filter in the stock air-box. On the stock turbo you will make the same power as you will with an aftermarket intake.
-OLMEK
Static Fitment
Feb 8, 2011 01:49 PM
2s2ks
Hawaii Classifieds
Jul 27, 2006 04:59 PM
2s2ks
Hawaii Classifieds
Mar 14, 2006 02:54 PM
rayray888
Sep 13, 2005 07:57 PM
