After Market Cams???
Old Jan 9, 2003 | 09:54 PM
amelnikov's Avatar
Car Info: 2002 WRX Sportwagon 292WHP
It depends on what car you are talking about and what you are doing with it. Please list your mods and intentions. Cams are always made for a purpose, low end, midrange, top end. Where do you need improvement? Assuming you have WRX, you don't need any until you start pushing 500 HP. Stock WRX cams are already pretty aggressive and have been proven to support in excess of 400 WHP.
Alex...
Old Jan 10, 2003 | 08:45 AM
amelnikov's Avatar
I would try one of the STI cams, they seem to be setup for that type of racing. Also I would try a manual boost controller, they give you faster spoolup that really helps with midrange punch. Also you may want to have your turbo upgraded, have the exhaust housing ported and get 18 or 20 G wheel in the compressor, that should move you pretty good.
Also try to get your chip remapped to give you a little more timing in the midrange, that should get you going as well.
Alex...
Old Jan 10, 2003 | 10:12 AM
BADWRX's Avatar
Car Info: 09 E90 M3 SEDAN w/DCT
I would just get the heads built...STi valves, JUN springs and retainers, and Jun cams.
The only thing is that you will need to raise your redline to 8K. The STi stuff will bolt directly into the heads, so you could go that route.
Old Mar 15, 2004 | 07:01 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
Jun, i-speed/crawford performance/ dpr, ion-perfrmance, b-spec usa, are a few companies that offer cams for the WRX.
However, they are all more than $700.
i<3dirt
Oct 20, 2014 10:26 AM
WRXLR8R
Apr 3, 2003 01:20 PM
skullguy
Feb 18, 2003 08:34 AM
skullguy
Feb 10, 2003 09:38 AM
AC_gohan
Nov 29, 2002 01:09 PM
