advice on BOV's
Old Feb 24, 2003 | 06:17 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
What your friend says IS correct. A BOV will hurt performance of a WRX.
If you're looking to get any real performance gains from your mods, stay away from intakes and BOVs. Neither will make any noticably power. Spend the money on an uppipe and exhaust system. Those will make real, noticable power. One last thing, stay away from the HKS downpipe. It is poorly designed and any power gained from it will be solely a result of deleting cats. Good luck.
Old Feb 24, 2003 | 06:18 PM
illmatic's Avatar
The stock bypass valve does make noise. It's the intake resonator chamber that silences it. Try removing it. An aftermarket intake will make it really audible as well as up-pipe and espcially downpipe. Stay away from cold air intakes even open filter ones if you can.
Old Feb 24, 2003 | 09:08 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Something to combat that is the GSF 50/50 hybrid BOV. It will recirculate 50% of the air back into the chamber and 50% back into the atmosphere.
Old Feb 24, 2003 | 09:47 PM
@Stoptech
But you still have to admit that the only reason to get it would be purely to hear the sound.
Old Feb 25, 2003 | 12:41 PM
@Stoptech
Re: intakes
Originally posted by I_Fry_Rice
aight, now that we covered the BOV's, would someone kindly suggest a high quality air intake? I don't expect it to make more than 5-10 ponies, but it WILL increase my throttle response and give me better gas mileage. I don't know about the WRX's ... but on my 95 civic EX it gave me 4 more mile per gallon.
(boy i'm glad i sold that rice burner hehe)
i'm telling you, the stock design doesn't leave much room for improvement. if you REALLY want to do something, just get a new panel filter and remove the silncer. that will let you hear the intake better and perhaps free up some ponies. spend the money on an uppipe. your turbo will spool at least 300 RPM earlier and you will have more power everywhere. then get a downpipe. i recommend the bosal because of the totally separated wastegate pipe and the fact that you can still retain a cat for emissions. that will add at least 10WHP at every RPM. trust me you'll like it.
Old Feb 25, 2003 | 07:52 PM
InfamousDX's Avatar
After havintg the Greddy Type S on my old turbo civic, yes I love the sound, but I can deal without it since I had it for so long. I don't want to waste $200 on something I don't need for a stock car.
Old Feb 26, 2003 | 07:14 AM
wannaberacing's Avatar
Car Info: 2002/2.5/sr40/400hp
BOV
http://www.airpowersystems.com.au/wrx/blow.htm
This is it.
You can't do better.
Dave@wannaberacing.net
