Accessport Stg II w/ top mount?
Old Oct 26, 2005 | 07:48 AM
PurduePhiGam's Avatar
Car Info: 2005 WRX
Looking to get a new top mount w/ bov in addition to my TBE. will the top mount allow for stage II? I wouldn't want things to get funky. thanks
Old Oct 26, 2005 | 07:51 AM
j*bishop's Avatar
Car Info: ass, grass or cash. no one rides for free
i'm runnin cobb stg2 91oct. w/header and jdm sti tmic. everything SEEMS fine...
no need for bov imho....
Old Oct 26, 2005 | 07:55 AM
wrx10404's Avatar
Car Info: 04' wrx
Lots have done it. I would get gauges though to keep an eye on things. Maybe a protune, to be sure.
As bishop said no need for aftermarket BOV. Don't waste your money.
Old Oct 26, 2005 | 10:46 AM
Car Info: 2005 WRX
well the guy who's selling the bov is just including it. so it's basically free. should i not worry about installing it, and just stick with the stock?
also with the intercooler, will i notice gains? or would it be more in terms of efficiency? (basically, should i buy, or not?)
Old Oct 26, 2005 | 10:52 AM
j*bishop's Avatar
stick w/the stock and sell the bov to offset some of what you paid for the top mount.
as far as noticable gains. that's gonna depend on how tuned your butt dyno is.
Old Oct 26, 2005 | 11:06 AM
Car Info: 2005 WRX
i dont get it...butt tuned? then tune it with the accessport at Stg II?
confused
Old Oct 26, 2005 | 11:58 AM
slvrsubywgn's Avatar
He means it won't be a huge, noticable gain unless you are very aware of small gains yourself, if that makes any sense. The TMIC will not give you large gains in hp, instead it will mainly give you the ability to run a larger turbo setup in the future. It'll add a few extra horse right now, but you'll only feel it if your "butt dyno" (meaning you) is very aware of small changes. Again, stick with the stock BOV. I don't know how I can stress the importance of this. The stock BOV is good for upto 20psi, or thereabout. By the time you're up that high, you'll lead the risk of blowing engine internals anyways. IF you do decide to run with an aftermarket BOV, %100 recirculatory is the best, as it will act like your stock BOV, but you will not hear the woosh. If you get a 50/50 or 100 percent atmospheric BOV, have it tuned right away, or your car will run like crap (ie idle poorly, run slower, etc.). And when you get the Cobb Accessport, they only have certain maps to reflash your ECU with, so if you want the optimum performance, and your car to run the best that it can (perhaps even better than when it came from the dealer), take it down to have it custom tuned to your setting, on top of reflashing with your Accessport. I myself will have mine custom tuned by Ed at EQ Tuning in the future, but there are plenty of other people that can custom tune, too.
Old Oct 26, 2005 | 12:17 PM
j*bishop's Avatar
^^very well put^^
if you're really set on a bov look into the worx one. www.worxtuning.com they came out w/a new version which i haven't seen to many reviews on but looks promising. i have the older 1.2v polished worx bov and it's very very nice. but, it's currently sittin in a box. i did a lil research on it when i first got my car and liked its quick adjustability and really wanted that, "pppssshh" sound. i've since grown out of it and have read enough post to know that aftermarket bov aren't needed for what i have planned for my car....
Old Oct 26, 2005 | 12:50 PM
Car Info: 2005 WRX
i'm really not into the bov, i was previously thinking about selling it once i got it. i've done my homework. but now you're saying to get it custom tuned, and then reflash it to stg II. i'm in the chicago area, could i do a google search on tuning garages? how much would this tune cost? thanks
Old Oct 26, 2005 | 01:04 PM
j*bishop's Avatar
you won't necessarily need a tune by adding just a tmic. if you think you're done moddin and to reap the full benefits of the intercooler then yes get a custom tune. since you already have the AP look for a shop who has cobbs protuner software. iirc you have bunch of tuners in your area. tune costs will depend on the shop.
Old Oct 26, 2005 | 01:07 PM
I'm sorry, maybe I wasn't very clear on that part. First you need to load a map on from your Accessport to your car, AND THEN you get it custom tuned. For example, if you had an uppipe, downpipe, and lightened flywheel on your car, the Accessport may only have a map for an uppipe and a downpipe, so it wouldn't recognize your flywheel and therefore wouldn't utilize it's full power potential. What a custom tune does is button up all the gaps and make your car run superbly. A custom tune WOULD utilize your flywheel and therefore pump out a few extra ponies, plus it will get rid of any knock, and make your car run not too rich or too lean (if you get a competent tuner). Most of the tuners I have seen usually charge anywhere between $125-200 an hour, and some even more. Tuning usually only takes between 1-3 hours. Hope this helps!
Old Oct 26, 2005 | 01:42 PM
wrx10404's Avatar
Car Info: 04' wrx
Call P& L. They can tune that sucker for you.
Old Oct 26, 2005 | 02:45 PM
silentbob343's Avatar
Car Info: POS
Just get rid of it you don't need it.
Old Oct 26, 2005 | 02:48 PM
Car Info: 2005 WRX
i hope you're not referring to the bov. i plan on selling it right away. as far as the tune, i think worst case scenario being $600 it's not worth (at least right now) getting my car tuned. as good as the deal is, i might just buy it and wait to tune it later to squeek out some extra beef. but until then you all are saying that she'll run fine at stg II correct?
Old Oct 26, 2005 | 02:50 PM
j*bishop's Avatar
you'll be fine....
