2nd opinion...
Old Aug 11, 2005 | 07:09 PM
de pilipino guy's Avatar
Car Info: none
2nd opinion...
i've been having white smoke coming out from the exhaust and for this past couple of weeks i've been really really concerned, because a fellow iclubber pointed it out to me that i should get it check(just in case)....
here's the problem, alot of times when i start the car and drive for about 10-15 minutes and come to a stoplight and white smoke would start coming out of the exhaust(some of you probably saw this at least once), when i press on the gas and blows alittle bit more and dissapear once i get rolling....
i've already talked to ryan@vakamon( i trust him, i really do..just want a 2nd opinion)..he said that it's minor...and that it's probably condensation or extra oil from blowby(something like that..RYAN pls correct me if that's not what you said to me..ahhaaha)..
Old Aug 11, 2005 | 07:46 PM
blue blurr's Avatar
Are you catless?
Old Aug 12, 2005 | 11:19 PM
is it cold out side?
is the motor cold?
Old Aug 13, 2005 | 12:03 PM
ej20boost's Avatar
Car Info: My 2009 FIT for sale!!!!!!!!!!
i get that too...usually car is not at operating temp. there is no valve cover leaks(like thru the spark plug seal for the v/c) would not hurt to check(wait..... OOOO yeah our spark plugs on the sides..... ok its going to be a PITA ) if you want, can i come & check it out?
WindingRoad
Apr 9, 2007 10:56 PM
Brian Lock
Oct 13, 2005 01:15 PM
Brian Lock
Oct 13, 2005 12:18 PM
de pilipino guy
Aug 19, 2005 07:53 AM
