250 whp
Old Feb 13, 2003 | 06:59 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Uppipe, downpipe, boost controller, intercooler hoses, and some form of engine managment. That'll get you there.
Old Feb 13, 2003 | 07:25 PM
stick's Avatar
more like full 3in turbo back exhaust in addition to up pipe, IC hoses, and engine management.
you need a bigger turbo. most HP that i have seen from stock turbo is about 240.
if u go bigger turbo then u need bigger injectors, fuel pump, and IC.
lots of tuning too
good luck
Old Feb 13, 2003 | 07:28 PM
teiva-boy's Avatar
lots of tuning too
good luck
TurboXS has already gotten 263HP form the stock turbo with no nitrous!
The mods were as follows:
Utec
TXS v2. TMIC
completely catless TXS exhaust
Vishnu upipe
Vishnu pulley
C16 gas
Can it be done sure. But it's all about engine managment.
Old Feb 13, 2003 | 07:31 PM
stick's Avatar
Originally posted by teiva-boy
C16 gas
sure u can do it but who has C16 at the pump in ur area.
i bet if u run pumped on that same car, the #'s would be alot less. like less than 250hp
Old Feb 13, 2003 | 07:56 PM
teiva-boy's Avatar
I've got C16 nearby my home, do you?
Eitherway, the point that I was trying to make is that you dont need a new turbo, nitrous, etc. Simple bolts-ons and good engine managment will get you to 250WHP.
I'm done with this thread.
Old Feb 13, 2003 | 08:09 PM
Dick Fitzwell's Avatar
cool, i will chime in here.
just my two cents, so take it for what it's worth: full exhaust, uppipe, some type of engine management, bigger IC. like stated above, with good gas and tuning you could get to 250 whp
without swopping out the turbo.
you can swop out the turbo w/o having to change out injectors/fuel pump, but you will be limited at how much hp you can make. anyway, hope this helped
-DF
Old Feb 17, 2003 | 10:19 PM
WRX34's Avatar
Car Info: 2002 WRX
Well I've got a friend who's shooting for the record in the 1/4 on stock turbo (going for 12.8 flat or better) and he should have well above 250whp on pump in order to pull that off. But then again he's got Ti exhaust, full catless, Link SA ECU, wlbro fuel pump, APS intake, Underdrive pulley, lightened flywheel, ACT clutch, diff locks, full bushing kit, STI mounts, short throw, and a whole bunch more crap I can't remember but he's trying to do it below 14psi also on the stocker...he's got this nice HKS turbo screaming for him in his room but it's not going on until he proves everybody wrong But then again we don't all want to do that because it's not practical for everyday driving. Just trying to prove it can be done..how easily is another thing....yeah injectors and turbo are a must for anything above that for us reasonable guys!
WRX34
minisiu
Jun 4, 2006 11:21 PM
bemani
Jan 5, 2004 04:40 PM
KXRicer
Mar 12, 2003 09:14 PM
amelnikov
13
Feb 11, 2003 04:59 AM
1WRX2NV
17
Jan 18, 2003 09:26 PM
