2003 WRX Wagon Overheating
Old Apr 24, 2017 | 08:47 AM
wrxfamwagon's Avatar
Car Info: 2003 WRX Wagon
Exclamation 2003 WRX Wagon Overheating
Please delete this thread. Created a new one in the bay area regional forum
Guys need some help on this one.
I have a 2003 WRX wagon that recently started having over heating problems(note during all this the temp gauge has never made it to the full hot mark). It began a week ago leaving home and the temp gauge started to rise. We were close enough to get back home, but on the way back home it dropped back down to normal and stayed there. First thing I thought was there was air in the system. I did a couple of different versions of removing the air. The car would act normal while doing this at home, but within 10 min or so after taking it for a test drive it would take off again. I then went ahead and replaced the thermostat with one from Subaru. Burped the system multiple times during the day until it wouldn't take any additional coolant then take it for a drive and bam temp spiking and air blowing cold through the defroster. Spent the day yesterday draining the entire system again burping the system till it wouldn't take any more, let it sit overnight and levels were full this morning. Took it to the gas station and on the way back same thing temp gauge took off and cool air through the defroster. I have no oil in the coolant, no coolant in the oil, and have a combustion leak tester for the coolant that tested clear as well. The water pump is making no noise or leaks as well. My only other thoughts as it seems the only variable is boost is that the turbo could be injecting air into the system(if that is even possible). I'm about ready to call it quits and just sell it.
Mods to the car, but most of these have been on the car since early in it's life.
Catless up-pipe and down-pipe full exhaust
Cobb stage 2 tune
and a bunch of other stuff that would have no affect at all on the engine.
IdahoEv
Jun 20, 2004 08:33 PM
Dead Pig
Apr 26, 2003 10:37 PM
trhoppe
Nov 26, 2002 07:32 AM
