04 WRX BAD Hesitation Btw 3000-5000rpm
Old Feb 18, 2004 | 12:45 PM
russellfujii's Avatar
Car Info: white wrx 04 sadan 5-speed
Angry white 2004 sadan wrx 5 speed
I have the same problem but the anly thing is that it comes around 1500 and 2000. I hate it! at first i thought it would go away but now that you mentioned it i think there is a defect too.
Old Feb 18, 2004 | 12:54 PM
TurnWRX's Avatar
recall all 04 wrxs
Old Feb 18, 2004 | 12:58 PM
Rock Strongo's Avatar
Car Info: 2004 WRX Sedan
I have this problem.
"The car will also somewhat violently buck on decel if coming off heavy gas...(does this a few times a day)"
I can't say that I have general hesitation in the lower RPMs.
Old Feb 19, 2004 | 05:21 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
i have a 04wrx and it drive perfectly. maybe bring your ecu back in for look.
Old Feb 20, 2004 | 03:09 PM
stevedood's Avatar
Car Info: _
Did you guys do the grounding mod?
Old Feb 20, 2004 | 03:29 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Bad ground. In particular the injector grounds that are bolted on the driver's side of the intake manifold.
Or
Mad MAF sensor.
Or
Faulty knock sensor.
Old Feb 20, 2004 | 06:09 PM
I have not done the grounding mod... yet. It is on my list.
Old Feb 20, 2004 | 07:40 PM
wrx10404's Avatar
Car Info: 04' wrx
Is it shuttering or more like a slight rocking like someone is pushing and pulling on the car. Some where here there is a thread that talks about this and the fix was to remove the downpipe cats. If it is, now have the dealer check the cats. They may place high flow cats on in place. Moderator Peaty may know what i'm talking about. As for the decel bucking i think its just the turbo. I have noticed it a few times but rarely. Usually if i am on the gas hard and i have to get out of it quickly before i push in the clutch. If you back off easy it's ok. This may go away. I am at 6000 miles and no trouble.
Old Feb 20, 2004 | 07:56 PM
wrx10404's Avatar
Car Info: 04' wrx
https://www.i-club.com/forums/showth...threadid=43825 Found It. I know this maynot be related but it is worth a try. Good luck
Old Feb 21, 2004 | 02:27 AM
ilivas's Avatar
I have an 04 sedan, with catless up-pipe and downpipe. The hesitation still persists. It does it in part throttle and full throttle.
Old Feb 21, 2004 | 02:36 AM
ilivas's Avatar
I'm gonna try the grounding mod tommorow
Old Feb 24, 2004 | 12:58 AM
I dont think it is turbo lag. i think its my left mud guard. its not that loud but its still erking in the morning. i hate it, but you can only hear it if your radio is off and your windows are up. all you 04s try turn your radio and role up your windows and tell me if you guys hear anything.
thanx
