Xede Stage 0 first impressions
Old Jan 16, 2004 | 12:39 PM
WRXncrew's Avatar
Car Info: http://goo.gl/XpkO0b & '99 SF 'S'
Thumbs up Xede Stage 0 first impressions
The Xede revision B unit is very easy to install. Totally plug-and-play. My only gripe is that the ECU cover plate doesn't really fit because the ECU harness and Xede adapter harness prevent the cover from fitting (need some spacers?). After installation, and a blank map the engine started right up as if nothing was added on (I like this).
With the provided serial cable attached to the Xede and the serial port on the laptop (running Win2k Pro SP4) installed the Xede 2.0.0.0 software (not the beta from the Vishnu site), the Xede was recognized right away (I got happy and excited). I then flashed with the Stage 0 CA 91 octane map. Started the engine and took it for a test drive.
Man, all I could say was WOW! This is awesome! I notice a huge gain in midrange power and torque. Now I feel that I am definitely not afraid to take on a stock STi, EVO or even an M3. Woohoo!
Old Jan 16, 2004 | 12:59 PM
gilmore25's Avatar
Car Info: 05 LegacyGT,06 Black STI Will be home Soon
Good to hear, it's like day and night you would never know so little would add so much power.
Old Jan 16, 2004 | 01:02 PM
WRXncrew's Avatar
I also noticed that maximum boost went up to about 17 psi on the Omori gauge.
Old Jan 16, 2004 | 01:06 PM
gilmore25's Avatar
Ya I've notice with my reflash that sometimes it peaks at 18 psi but drops down to 16 PSI planning on any other upgrade to the engine?
Old Jan 16, 2004 | 01:11 PM
WRXncrew's Avatar
Yes, the future holds a ported and polished VF23, STi injectors and a Walbro FP and a STi TMIC.
Old Jan 16, 2004 | 01:33 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
damn, it sounds like you had a good drive home last night. i'm going to be interested to go for a ride in your car with the new power.
Old Jan 16, 2004 | 01:52 PM
meilers's Avatar
For the record... Xede or not, don't challenge the M3s
Old Jan 18, 2004 | 01:12 AM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
thats nice to hear, if my car gets to the end of the warranty without anymore problems, then i was hoping to get things from vishnu
Old Jan 18, 2004 | 06:08 AM
SUB-ZERO's Avatar
Yeah, those M3 are quick (the 03/04 models). I had trouble spanking one and I have a TXS STG4+. Still got him though !
-SZ:banana:
Old Jan 18, 2004 | 04:08 PM
I have installed Xedes before, and if you route them right, the ECU cover plate fits right back on. Try running the harness up towards the glove box so that the Xede sits kind of against the firewall above the ECU cover.
Also, don't get too cocky just yet... you can beat most WRXs now, but an STi or Evo or M3 will eat your car for lunch. A new turbo, injectors, and full exhaust will change that, however...
Old Jan 18, 2004 | 10:40 PM
Juliano's Avatar
Car Info: 2002 WRX
I went to Home Depot and bought nylon spacers, longer bolts and some extensions. My Xede sits under my ECU plate.
Bouncer
Dec 20, 2010 11:54 AM
josh
Dec 9, 2004 02:09 PM
Magish
Oct 27, 2004 10:23 PM
